![]() | Home > Puma (Tdci) > Heater Controls |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Hi Phil
Have a look here Daniele kindly hosts Puma workshop manuals, it should have the information you need https://onedrive.live.com/?cid=4bc2d89c85c...C171%21552 Cheers John 2014 110 2.2TDCi XS Station wagon - GONE 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - GONE 2024 110 D250 X-Dynamic HSE |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
My mates did this. I just took off the front of the panel & had a fiddle.
I think it was just 2 things trying to select at the same time ![]() Any how put it back & alls been fine ever since ![]() 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
Phil_D Member Since: 09 May 2014 Location: Perthshire Posts: 25 ![]() |
John, thanks for the link, I found the relevant section. The diagrams are useful and I learned some new terms ('blend door control cables', marvellous!).
Chris, yes, looking at the diagrams I'm guessing it's simply that things have got tangled. Very helpful to see what's behind the panel before removing it! Phil. |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
I had the same, can't quite remember but I am sure it was the force of the fan being on holding it in position?
Have a fiddle in a few settings first ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Thanks for the suggestion but I don't think any amount of fiddling will free it - panel off, I'm afraid.
Phil. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17919 ![]() ![]() ![]() |
Quite often problems with the sliders are down to the plastic melting and deforming due to the heat from the bulbs illuminating the controls, a very common problem.
Be very careful with the heater control unit, it is only available as an assembly and is STAGGERINGLY expensive! |
Thanks, I'll be careful!
Phil. |
