Home > In Car Electronics > Hidden FM antenna
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Hidden FM antenna
Anyone got a hidden fm antenna that gives good fm reception?
I have replaced the standard LR antenna with a CB antenna and put a Zetagi DX27 fm/CB splitter
However, FM reception is not great (and I suspect , though not tested yet, that CB signal will also degrade)
So I want to leave the CB antenna where it is and install a dedicated but hidden FM antenna
Any recommendations for one?
Post #336349 7th Jun 2014 10:52am
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Why not bung a Disco / RR / FL sharkfin on the roof? Should fit nicely on the slope at the front, without increasing overall height.. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #340341 23rd Jun 2014 11:01pm
Bear in mind with above you only have two options, offset or twin.
You cannot have a centralised one due to support rib in the centre..
Post #340365 24th Jun 2014 12:12am
BigRuss
Well you could have it centred if you drill through the rib and then add a couple of strengthening plates either side of the rib Russell
2011MY 110 XS USW Black
Post #340376 24th Jun 2014 6:43am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Is the radio aerial in the fin..?
On my D4 I thought the radio aerials were the wires in the two rear side windows. I always thought it was the GPS aerial in the fin..?
But clearly I've no real idea..Smile
Simon
Post #340380 24th Jun 2014 6:48am
The sharkfin is a GPS antenna Thumbs Up Darren
Post #340385 24th Jun 2014 6:55am
munch90
with the sharks fin radio aerial they are normally amplified , so you need to have power up there as well
you can get cheap ones that are not amplified but guess they would not work very well
Post #340388 24th Jun 2014 7:12am
kmac
The whole idea was to not have to drill another hole for antenna
I may as well replace the stock antenna in the original position and mount the CB on the rear using a PSM-1 mount
Post #340469 24th Jun 2014 3:12pm
There is internal stick on, usually on the glass but they can often differ in quality.
Post #340477 24th Jun 2014 4:07pm
