![]() | Home > Puma (Tdci) > Puma windscreen - easily scratched? now need to fix |
Rejel seem to be a supplier of windscreen repair stuff (and Dinitrol, plus other products interesting for a Defender owner
![]() http://www.rejel.com/rejel-store/windscreen-repair.aspx http://www.rejel.com/rejel-store/pit-fill-polish/espr25.aspx Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
jellewers rouge is for polishing glass , but it would probley take weeks to polish a windscreen!
I would say wotever scratched your glass was something other than a Scotchbrite/washing up pad,0000 grade wire wool has been used for eon's for glass cleaning,probably that much cr*p stuck to your screen you've never noticed the scratches before
![]() Back o/t, if you want to polish scratches out of the glass you need this which is cerium oxide polishing compound and rayon felt pads with a drill attachment,oh, you wont be able to do it by hand either. Mines full of scratches and chips thinkin of swappin it out. http://www.ebay.co.uk/itm/GLASS-POLISHING-...&rt=nc Pov.spec,ftw. 2006, 110,TD5. |
I think you've been very unlucky! I've never had a scotchbrite pad scratch a windscreen!
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Unless it's been inadvertantly dropped and picked up some grit. If you go through life with your head in the sand....all people will see is an ar5e!!
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
Or swarf etc, easily done and you'd probably not even see it.
It would be too labour intensive to polish them out. If Defender ownership is anything to go by wait until the next deluge of rain and the unrepaired potholes to cough up a few stones and you may have to replace it anyway. Think I'm on my fourth now in 6 years.
![]() Treat every day as if it is your last....one day you will be right!! |
Sonarmender Member Since: 04 Apr 2013 Location: Guz Posts: 338 ![]() ![]() ![]() |
A Jockbrite pad either green or red should not put any scratches in your screen if used correctly.
Jewellers Rouge, Brasso or T cut is the only way to remove the scratches, depending on the depth of the scratches will depend on how long you will be polishing, you may there a while. You only have one life, live it....forget the cost. 90XS Hardtop |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5981 ![]() ![]() |
Personally I'd smack it with a hammer and get a new windscreen fitted though insurance company.
Andy |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 462 ![]() ![]() ![]() |
Thanks for the replies guys, guess I'll justhave to live with it, it's not normally noticeable anyway, just depends on the angle of the sun.
![]() 88" Series One Old Norton ![]() Minerva |
I did the same on my Q5 windscreen, scratched it in places, the green cleaning pads are quite scratchy
