![]() | Home > Tdi > Recommendation for Defender 110 300tdi Exhaust? |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
It purely depends on how deep are your pockets. Each and every manufuacturer will naturally profess theirs to be the best. Stainless steel exhaust systems complete can vary considerably in price by up to nearly £350 but they all do the same thing.
I have a stainless system that was made by a 'Horse Dentist' as named by another provider who's exhaust cost considerably more than mine. With a lifetime guarantee either way who really cares? Do a search and make your own mind up would be my advice. None of them will make your Landy drive like a Porsche or Ferrari afterwards or make old age pensioners cover their ears and have heart attacks as you drive past. If it's function over form you want with a good guarantee at a good price......Griffin. 'Stainless Exhaust' in the search box reveals 140 threads that should keep you busy for a while and provide you the answers you seek. Treat every day as if it is your last....one day you will be right!! |
| cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642
In that case then i would sugest buy a new std exhaust and tweak the pump = same std sound and more power 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
| foxhound Member Since: 02 Mar 2013 Location: United Kingdom Posts: 363
thanks - I put in all sorts of combinations of exhaust, + 300tdi etc but did not put stainless in duh! who was your horse dentist? 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
You don't advocate stainless? Why's that? Won't more power increase MPG or am i being stupid? thanks for your advice. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
Foxhound you have a 'pm.'
The landy already had a new exhaust fitted when i bought it in February 2.5TD ( 200TDI ) and decided to alter my exhaust to come out of the rear wing and at the same time i decided to fit a straight through exhaust aswell and ordered a straight through middle section from paddocks which was a stainless steel pipe then found out that the exhaust down pipe wouldn't fit the new middle pipe ( flanges was different ) then figured out my exhaust was infact a 2.5TD exhaust fitted to a 200TDI so ordered a new 200TDI down pipe to fit the middle pipe then made my own rear section to come out of the rear wing then tweaked the pump later
Click image to enlarge Click image to enlarge
Graham
In real terms the 200 /300 engine is restricted in power in std form giving less mpg so giving the engine more power gives better mpg aswell
Yes but by tweaking the pump or going with a stainless exhaust?
Did the question get answered? MPG gains........Not necessarily, with more power your driving style will change negating any gains to be had of any mpg increase which will hardly be noticeable if at all in this scenario. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
What is the benefit of the exhaust exiting at the rear side wing? Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Probably a bit of both as i wanted to do the exhaust mainly for the sound but i recently fitted a set of insa turbo special tracks and lost a bit of power which i expected then got reading about tweaking the injection pump all this happened at the same time if you know what i mean but by fitting a straight through exhaust on its own should make some difference a bit like replacing a 300tdi catt with a de-catt pipe really a bit more power and slightly better mpg but nothing drastic
The sound as you are removing the rear silencer and i fitted a straight through pipe aswell 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
In theory yes but i am 53 nearly so not eggzackly a boy racer 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
Foxhound,
In realistic terms your exhaust will never pay for itself. No point throwing a horrendous amount of money on an expensive top market exhaust that may cost you more than you need to pay. If the vehicle as explained is a 'keeper' sensible thing would be to go for a cheaper stainless or standard perhaps? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
I looked into getting a stainless exhaust system for my 200Tdi and decided that I could replace every section of my exhaust 3-4 times over about 15 years for the price of a stainless system so decided to stick with cheep and cheerful mild steel from paddocks.
3 years on still happy and front section is only stating to go rusty, mid section looks as good as the day I replaced it (stone took umbrage to it and flattened it while dragging some logs out a forest) and the rear section is looking a bit flakey but still got years of life left in it. Just food for thought |
