Home > Maintenance & Modifications > 110 van cargo area to cab bulkhead
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Having searched a bit, I've been unable to find a solid bulkhead to blank off the area behind my 110 van's seats from the cab. This is a two door 110 hardtop incidentally.
I'm thinking of a steel sheet with just a small hole to allow the rear view mirror to remain in use and that also doesn't stop the seats going fully back.
Does anyone know of such an item please? I could make one, but at this rate, Defenders will have gone out of production before I've even driven mine!
Thanks for any help.
Post #338536 16th Jun 2014 7:23pm
jimbob7
Think DIY is your best option,they do come up for sale occasionally as the utilities trucks fit em,but I don't think they are off the shelf products,outa curiousity why a solid cargo barrier? Pov.spec,ftw. 2006, 110,TD5.
Post #338552 16th Jun 2014 8:03pm
Romadog
Not a genuine supplied item. Fitted by Special Vehicles to vehicles for Utilities.
Companies selling ex- utility vehicles may have one, taken from a vehicle if a purchaser didnt want it
Post #338553 16th Jun 2014 8:05pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Post #338554 16th Jun 2014 8:06pm
Spruce Pirate
Scotland 2013 Defender 110 Puma 2.2 HT Zambezi Silver
If it's a commercial vehicle, depending on what you're carrying (e.g. fuel, chemicals) you should have a solid barrier to prevent hazardous substances entering the cab. A dog guard wouldn't cut it as, in the event of an accident where a liquid container was punctured, it would not prevent the driver and/or passenger from becoming contaminated.
Cue discussion on whether the bulkhead would actually prevent liquid entering the cab. Whistle Dirty Deeds - Done Dirt Cheap
Post #338556 16th Jun 2014 8:17pm
Joe the Plumber
Thanks folks. I want to be able to make the load area as secure as I can as I sometimes have some expensive kit in there. If the felons can only attack the back door to get to it, that makes it that bit more secure (or it should do once I've finished my back door mods).
Post #338564 16th Jun 2014 8:55pm
PaulMc
A dog guard will give you the correct shaped frame and fixings -
which you can then 'panel over' with steel or aluminium sheet, leaving your 'mirror' window.
. Paul.
Post #338717 17th Jun 2014 12:43pm
