![]() | Home > My Defender > My 200TDI With Straight Through Exhaust and Side Exit |
| mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142
nice! classier than the side exit where its before wheel.
| cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642
Yeah it looks a bit cheesy some how fitting it before the rear wheel, the only advantage i can see there is the fact that you would have a shorter exhaust and probably with having the N/S window closed you will still here the exhaust better than you would having it coming out after the wheel
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) Last edited by cornish rattler on 16th Jun 2014 6:57pm. Edited 1 time in total |
does it rattle against the bodywork?
It did do but i have today fitted a rear bracket that comes off the rear X member to hold the tail pipe up where it comes out of the hole also i didn't realize when i originally fitted it that the exhaust tail pipe was fowling the body strengthener as i couldn't see it when i fitted it but i have sorted it now by cutting some of the body strengthener away to clear the exhaust
here are a couple of pic's
Graham
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
