Home > Puma (Tdci) > Air intake temperature
Page 2 of 2 <12
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
About 10 minutes with turned of engine: 50! And still rising!
Post #337790 12th Jun 2014 6:32pm
K9F
So what? The 91 degree heat emanating from the engine has to go somewhere. I wouldn't worry about it. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #337792 12th Jun 2014 6:33pm
zone30
At 52 I turned on engine and within 1 minute it dropped to 33. Still more then ambient temp.
So it's pulling in air from outside cooling it down again.
Post #337794 12th Jun 2014 6:36pm
zone30
@K9F:
That's my whole point. If you protect the intake from that, you gain efficiency, maybe not much but so will the cost to insulate be.
Post #337799 12th Jun 2014 6:56pm
landy andy
Where is the sensor that is taking the temp? What is it mounted in?
Andy
Post #337801 12th Jun 2014 7:03pm
zone30
Plastic tube, 10cm after the filter box.
But it's the whole duct that heats up, both before and after the filter box. The part from the wing to the box heats up first and most.
I think in total it's about 1m long.
Post #337802 12th Jun 2014 7:06pm
Page 2 of 2 <12
