![]() | Home > Tdi > Will a 2.5TD exhaust restrict a defender 200TDI |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Shouldn't do, from memory they are same diameter only thing different is flanges.
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
I don't know but would assume not as it's intended for a more powerful engine ie greater gas flow?
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8406 ![]() ![]() ![]() |
i have fitted three tdi to 2.5TD exhaust systems over time, all worked no problem. Cheers
James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop Last edited by jst on 9th Jun 2014 10:16pm. Edited 1 time in total |
Well as yours would have been a TD originally I would assume that you still have a TD exhust with a converter pipe down from the engine to the old system.
If yours is a defender 200tdi engine then I would just replace the exhaust system with a 200tdi system and move any brackets that need moving. Whats wrong with your existing system is it rotten? |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
No the exhaust is nearly new but we have just bought a straight through middle pipe but the flanges are different aswell as the bore of the exhaust is a lot smaller than the new straight through pipe we have just bought so thinking of buying a new complete 200tdi exhaust but using the rear silencer just for the flange so we can fit some flexi pipe to but could quite end up buying a used rear silencer to do this depending on price and availability
![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
Are there no specialist exhaust places or engineering contacts you may have that could just 'rework' the existing flanges for you? Be quicker and less hassle I would imagine? If you go through life with your head in the sand....all people will see is an ar5e!!
Its ok we will get a new 200tdi exhaust and sell the old but nearly new 2.5td exhaust
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1665 ![]() ![]() |
Can be made to work but not ideal due to size difference
Son fitted the new front pipe and straight through pipe yesterday but need to sort out the tail pipe still but we have found an exhaust place that will make us a solid but bent to shape tail pipe fit it inc any brackets needed and all we need to do is cut the hole in the rear wing so hopefully it will get done next week.
had it out just to see how it is with the new exhaust on and its quick but a little noisy due to not having a tail pipe fitted and the turbo lag has virtually gone ![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
