![]() | Home > My Defender > Bit more progress on the soft top conversion. |
garethmorgan50 Member Since: 16 Jan 2014 Location: Herefordshire Posts: 94 ![]() ![]() |
When you say speedliner front and back, which bits do you mean? and what is that costing you if you don't mind saying?
Fullfat Member Since: 30 Apr 2014 Location: Lincolnshire. Posts: 271 ![]() ![]() |
I'm having the inside of the rear tub and tailgate speedlined and also the front seat box and floor.
I'm colour matching it as well, cost £300 for rear and £200 for front, very keen price compared to some. Wanted something to cover up the wear and tear and update the look. Could have re sprayed it but wouldn't stand the dogs giving it the treatment! |
Should be good.. would be interested to see some photos when its done..
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767 ![]() ![]() |
"and also the front seat box and floor"
Are you having them coated in-situ or off the vehicle? I ask because if done in-situ surely that will make any future access very difficult and/or damage the coating when you try to undo screws, lift the floor panels etc? Even if the clutch / gearbox etc is currently in excellent condition who knows when failure may occur resulting in damage to the (quite expensive) coating? ONE LIFE, GET IT! |
hi litch, i thought about that beforehand the seatbox lids done separate and gearbox tunnel also. all floor bolts and seatbox bolts out first, spent an age drilling out all bolts and replacing with stainless so the sprayer could do it without any hassle, as i am paying for his time thought it was my time wisely invested, so any issues later not an issue getting to the areas.
Have you had the re spray done, has it come out well.. Any pics?
No not yet, I cannot get back to collect until Sunday, anticipation is killing me!!
Collect the soft top tomorrow as well. |
Who is supplying the new soft-top? ONE LIFE, GET IT!
all wheel trim are supplying the soft top, in sand with windows and I'm using the tenex fittings
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
you just going for the standard sticks arrangement and their seat belt bar?
No I had a hoop set made by purley metal, it similar to the nene overland setup on their softtops.
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1732 ![]() ![]() |
Its a bit more than similar, it is theres they use on some.
Looking forward to seeing the pics when the hoods on and be interested to hear what you think of the hood ![]() |
Funny you say that thought there was an amazing similarity to purley metals hoods and I noticed that all wheel trim supplied nene overland as well.
Even the sprayliner is done by the guy who used to do there's until they ![]() Still not going with the camel badge having my own made, a jack Russell badge on the front as I bought the land rover to take the dogs out! My wife thinks I'm mad. ![]() |
interesting stuff. My tilt/bracketery and "heavy duty stick set" will be coming tomorrow from All Wheel Trim..... i look forward to seeing yours, and if its the same as the purely metal one. Kim from AWT said he has a company "down south" make them for him in a non-specific kinda way. It will be 42mm ext OD, 3 uprights on each of the capping holes but no connection down to the chassis. The thing is galv and powder coated.
Cant wait! need to do it before the sun ![]() |
