![]() | Home > Puma (Tdci) > Glove box |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 ![]() ![]() |
Try here
http://www.defender2.net/forum/topic27521.html?highlight=mud+box ![]() DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
I fitted the Mobile Storage Systems glove box conversion a while back... Only takes about 30 mins from start to finish.. Very solid bit of kit, and IMHO, well worth the money.. ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
Def Junkie Member Since: 30 Dec 2013 Location: Somewhere in Paradise Posts: 79 ![]() |
Many thanks for your help guys. Much appreciated
Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 285 ![]() ![]() ![]() |
I went with the Mud one as it has a full length hinge. Very pleased, found a rubber mat on ebay and cut it to size to fit inside. 2008 Defender 110 XS CSW
Volvo XC40 Recharge Triumph T120 BMW R1300GS G0UBX |
th1208 Member Since: 06 Feb 2013 Location: United Kingdom Posts: 88 ![]() ![]() |
Fitted one of these the other day. Very pleased with it.
SWMBO cut out some of the black rubbery anti-slip material to line it. Jammed the edge under the long hinge to secure it. Sorted!! Cheers, Tony |
rory_mcw Member Since: 17 Sep 2009 Location: Angus Posts: 78 ![]() |
I fitted mine tonight,
It isn't my cup of tea, the top lid is not the best fit IMHO. |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3798 ![]() ![]() ![]() |
Which brand?..There are threads on the forum with a fix for badly fitting lids.
Pickles. |
It came from mud stuff,
I will get a solution sorted ![]() |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
I have NAK one fitted before other suppliers copied the idea expensive but good fit etc etc never regretted DEFENDER 90 TDCI XS,
The Mudstuff one is manufactured by Mobile Storage Systems and is the same kit that we use in our trimmed leather version. The one failing in the kit is that replacement screws are not supplied for the hinge to be attached to the dash and so people tend to reuse the original dash top screws which have too big a head and stop the lid closing properly. If this is what you've used, replace those two screws with countersunk ones and I'd be surprised if you weren't then delighted ! |
I can see where the original torx are holding the lid up.
I am also not keen on the nut covers for the lid, I think I'll try to figure out something to get it looking original. |
Take a look at our leathered lids - www.fcx.co.uk - we can use your existing kit if required ....
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 ![]() ![]() |
Have you seen my attempt Rory? http://defender90xs.blogspot.com/2014/05/g...ation.html http://defender90xs.blogspot.co.uk/ |
