![]() | Home > Maintenance & Modifications > Rear body capping protection |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3673 ![]() ![]() ![]() |
Im happy with ACF50 for this, but others say use wax, ACF50 comes with a straw. 1 negative is it runs down the body for the next couple of weeks a second is that it needs to be reapplied every year DEFENDER 90 TDCI XS,
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
Hi Steve. Yeah, ACF 50 is a good option. You need something nice and thin that will 'creep' into the joints and all the little gaps around the rivets. A thin cavity wax such as Bilt Hamber Dynax S50 would also be a good option. ACF 50 aerosols come with a single straw taped to the can. If you cut the end off at a 45 degree angle you can get it into the joint a bit more. Be ready with some kitchen paper to catch the drips - it dribbles down the body sides very quickly! Especially if you use a cavity wax because it sets as the solvents evaporate out. Getting anything in there is going to be better than nothing. The corrosion will already have started sadly, so it's basically a case of slowing it down as much as you can.
Also worth bearing in mind that ACF 50 is an oil essentially, so once that's applied nothing else is going to stick. So if you think you might want to try a cavity wax do that before using ACF 50. You can use ACF after a wax, but not advised the other way around. 2005 Td5 | 90 Station Wagon | Tonga Green |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20895 ![]() ![]() |
So a clear wax then ACF 50 would be ideal then.
![]() Not expensive and will be done this summer I think then. My ideas of rust proofing is to cover everything that can be where possible. And if nothing needs to gone apart it can be built back together with it, Dinitrol in my case. The cappings I'm noticing are not the vertical or horizontal really but the triangular sections, it's not rust but very slight discolouration on the edges. There's very like gap under there and I think the issues is more that it's the thin paint on the edge than from underneath. Saying all of this it's only noticeable set all if you specifically look for it and with in a foot or two if that. My 90's 7yrs old this year and kept outside so I font think it's doing doing bad at all so far. Thank-you for the ideas especially the wax in advance. ![]() |
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 419 ![]() ![]() ![]() |
Another vote for acf50
