MudUK Tunnel Tray USB Port, how do I wire up?
Is it easy for a non-electrical person like myself to install a USB Port by running the supply wire direct from the fusebox? under the transmission tunnel matting and use the spare fuses within the fusebox to provide a fused supply, and how do I do this?2001 90 TD5 CSW Alveston Red Manual
4th Jun 2014 10:02pm
mrd1990
If you take the fusebox cover off, you can push the wire up in the top right corner and it should pop out where the wires for the radio and cigarette socket come out.
From there you can take a direct spur for both negative and positive from the cig socket which is ignition controlled.
I've got all sorts of stuff using this route
5th Jun 2014 12:37am
timtom1
thanks I will have ago and take pictures 2001 90 TD5 CSW Alveston Red Manual
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
