Home > Technical > TD5 EGR
roel
TD5 EGR
Am I thinking right? Please read the rest before saying: NO. Rolling with laughter
As a quick first step before removing the complete EGR system, I was thinking off blocking the vacuum line at the T piece next to the engine with a small plug and some sealent. So the vacuum doesn't reach the actuators.
Am I correct to think that this way the EGR valve doesn't operate and the exhaust gasses don't get in the inlet system? Roel
2003 90 Td5 (2009-now)
Post #33562 2nd Jun 2010 10:08pm
K9F
Sorry Roel, but I don't know the answer to your question but from the following links it appears to be 'common practice' to blank the EGR AND plug up the vacuum pipe.
http://www.landyzone.co.uk/lz/f8/best-way-...74949.html
http://www.lro.com/forum/viewtopic.php?t=3...f557a77b7e
http://forum.landrovernet.com/showthread.p...king-plate If you go through life with your head in the sand....all people will see is an ar5e!!
Post #33566 2nd Jun 2010 10:19pm
roel
Thanks K9F, I will do the proper job in the future but thought about a quick middle solution for the time being. Roel
Post #33570 2nd Jun 2010 10:32pm
K9F
Roel,
I think the worse that would happen is that you will get an engine management light on....If it was as simple as blocking the pipe with a ball-bearing they wouldn't sell or have any need for the blanks I would have thought!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #33572 2nd Jun 2010 10:38pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Disconnect the plug on the vacuum control valve on the right hand wing.
On pre 2002 there will be one control valve, post 2002 there will be two.
Pete
Post #33573 2nd Jun 2010 10:40pm
roel
I thought if you unplug the (for me 2) it could throw up faults in the ECU. I thought if you don't get vacuum on the control valves the ECU thinks they are still working but they don't. Roel
Post #33574 2nd Jun 2010 10:45pm
Zinke
Didnt throw and codes up for me (been checked on Nanocom many times since its been disconnected). And if it does they only come up once as far as i can tell. If they are disconnected the ECU knows they are not working and fuels accordingly. If you just blank it off the ECU thinks there working and fuels the engine for a working EGR when its not actually working.
On mine i have the EGR valve completely removed and the vacuum pipes removed and the control valves removed.
Pete.
Post #33578 2nd Jun 2010 10:54pm
