![]() | Home > Off Topic > caravan luck (or lack of) |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
So went away the weekend and borrowed the parents caravan which was spotless until I borrowed it last year and bashed the rear corner....managed to get it repaired before they returned from their holidays
![]() Anyway borrowed it again this weekend and guess what........? Yep bashed the other rear corner ![]() Sat nav sent me down a small lane so was only going slow when I went through a puddle that almost spanned the whole lane....BASH Wtf! stopped had a look and hey presto the back corner was bashed and yet couldn't see what it had hit.....in some puddle was a wheel trim and wheel arch liner.....put 2 and 2 together and only explanation I can think of was almighty pot hole.... caravan wheel dropped into it and back of van hit floor!!!! Blast. |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
id of burned the 110 and the caravan there and then if i was you. get a saloon car and a hotel next time
I believe you may be able to claim off the relevant council if it is designated an adopted road and not private. Worth perhaps enquiring. You could fix it.........
Then burn it! ![]() Treat every day as if it is your last....one day you will be right!! |
But first double check that your insurance for fire risk is fully up to snuff.... You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
maybe you need a off road caravan like this
eBay item number: eBay Item No. 251540617921 |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
that's not a caravan. Mine has a wash room bigger than that. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5139 ![]() ![]() ![]() |
What that needs is a a motorbike attaching to it, what a brilliant sidecar it would make ![]() |
Someone has chucked some tyres in the road now to prevent any more problems....
Anyhow I forgot the punch line.... can anyone recommend someone close to b'ham to fix the damage....minor damage to fibre glass / abs but the alloy channel needs some serious bending. Got photos and will see where I get with claim on council. |
Looking at that awning, if a gust of wind got under that, I think you would not just have an Off Road Caravan but an off the ground caravan as well. ![]() [URL=] ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Alloy channel? Do you mean the chassis of the caravan if so its a possible right off. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1859 ![]() ![]() ![]() |
Is the caravan level or nose high when hitched? Could be the reason you've wiped it out (twice!)
channel the awning slots into ? |
Yes. Channel awning slots into not chassis rails.
Ickle. Yes van is a little nose up but much.
This time I feel it was purely bad luck and suspect the pot hole is like a plunge pool. Last time was down to a lack of experience...went over a grass verge which I knew def could take in its stride but didn't give due thought to what I was pulling ![]() |
