Home > Puma (Tdci) > Is this normal?
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Is this normal?
So I had a brand new transfer box fitted under warranty...
The little stick I can push to one side and it pops back to what I think is a middle position. Is there a middle position for difflock?
So as it feels like there is I was worried it was constantly in lock, so I jack up my right back wheel to check. When I try to turn it, it does turn (thank God), but it seems my brakes are rouching, or something is making a simular sound as well it seems to have some resistance as it does not turn completely freely.
The wheel does not feel abnormally hot however...?
Post #333493 25th May 2014 5:32pm
ericvv
As to the little diff stick, mine is exactly the same, but it is just normal. A few years ago I had the same worry as you when I noticed that from right position it moved to something like a center position, I checked here on the forum, also with my dealer, but nothing to worry about, the diff only locks when you really push the stick left and the light goes on.
As to your brakes, that is probably a different issue. Get it to the dealer asap as understand your warranty is running out.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #333497 25th May 2014 5:39pm
zone30
Just checked all 4 wheels and it's the same on all 4.
Will get a look over by an independant next week. This guy does mainly Defenders and builds his own competion buggy's so he should be able to put my mind at ease or not.
First time I went there he taped up a bunch of electrical wires and tubes Shocked
I wanted to make sure these things are not a potential driving hazzard.
The stick is weird though, can't remember having that with the old box. I was worried there for a second.
I will still pose the question though.
Thx for the quick reply.
PS I've ordered a 2 year warranty extention anyway. Seemed worth it in the end.
Post #333504 25th May 2014 5:54pm
fatman
Greece 2007 Defender 110 Puma 2.4 USW Keswick Green
If while turning the wheel by hand,the ignition was on,then its the traction control engaging and braking the wheel even if the engine is not running.
Post #333509 25th May 2014 5:58pm
zone30
On or off, makes no difference apparently.
Post #333512 25th May 2014 6:07pm
Don't forget that if you jack up any one wheel and turn it you're also spinning the axle diff gears, the centre diff gears and transfer box internals, and in the case of a rear wheel the handbrake drum as well. It won't just spin freely.
Post #333517 25th May 2014 6:19pm
zone30
Yeah but the metal slipping sound seems to come wright from the wheel I turn itself. I should not hear anything then, wright?
Anyway as it seems to be the same ln all four wheels, chances are that it's normal.
My sons golf had slipping brakes a few weeks back. It melted all the rubbers of his shocks and you could fry an egg on his rimms. Like I said, no abnormal heat on mine after an hours drive. Would be cooking as well if was bad I would think, but better be safe then dead I guess.
As it is my first defender, I have no point of reference, which makes me question these things. Like to have a logical explanation.
Post #333522 25th May 2014 6:34pm
