Home > In Car Electronics > Weird one... Engine revs speaker whistle |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2725 |
Today my 110 developed an engine-revs related hiss/whistle through my rear speakers.
The engine revs directly control the note of the whistle! Interference with wiring from the engine? The rear speakers were added by me a few months ago and are 6x9s wired directly from the standard rear wiring. Suggestions? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
24th May 2014 10:14pm |
normally comes from alternator
24th May 2014 10:21pm |
Sorry Steve you lost me there with the hi and low level inputs? Cheers, David
24th May 2014 10:44pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19650 |
I'm assuming you have an Amp? If so if you took your audio signal from the rear speakers to the Amp for 6x9's that's a hi level input.
If you use RCA connections from HU to the Amp instead that is low level. Low level signals generally is the best option. Make sense? |
24th May 2014 10:50pm |
No they run direct from the standard rear speaker wiring actually, no amp...
Should I just check for loose connections etc? Only appeared today... Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
24th May 2014 10:57pm |
can be down to bad earth or earth position , have you got any earths direct to battery
24th May 2014 10:58pm |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
This is normally an issue on older vehicles. Your 2010 truck should have shielded cables and therefore no alternator whine. Can also be a bad earth.
24th May 2014 10:59pm |
I would start with connection to rear speaker where are rear speakers ? is it only rears ? |
24th May 2014 11:00pm |
LED lighting can also have an effect in some cases, rare but worth thinking about if anything is in the close vicinity.
What power consumption are the 6x9's? Ideally if just running of the rear speaker wires and HU they shouldn't be no more than 50wRMS which most are more than that. As mentioned above alternator issues are usually with older vehicles. Is the Alternator producing a steady voltage? That might be worth checking especially with engine running under revs. |
24th May 2014 11:09pm |
