Home > Td5 > Unknown connectors.
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
Unknown connectors.
Just when I thought I had familiarised myself with the car, out of nowhere pops these two connectors, okay, from behind the nearside headlamp.
What are they, what do they do? Everything I have, works, so am I missing something? It wasn't me!
Post #333214 24th May 2014 2:01pm
For electrically levelling headlights, and the alarm BBUS unit
Post #333216 24th May 2014 2:02pm
ozzy57
That were quick.
I have neither of those, however I have acquired a BBUS from a P38, so hopefully that'll be plug and play. Headlight levellers, nah! It wasn't me!
Post #333219 24th May 2014 2:09pm
Yeah, was sat at my desk at work burning some cctv discs
TheP38 unit should work... Let me know as I want to fit one to mine
Post #333231 24th May 2014 3:05pm
Romadog
BBUS and alarm horn not headlamp levellers??
Post #333284 24th May 2014 6:35pm
munch90
I go with bbus and horn , leveller plug is smaller with more wires
Post #333285 24th May 2014 6:50pm
ozzy57
Horn is plugged in and working, so not that. It wasn't me!
Post #333288 24th May 2014 7:03pm
munch90
is yours hard top or pick up?
is there two horns in there (one "get out of my way horn" ) and one alarm horn
Post #333293 24th May 2014 7:17pm
ozzy57
110 csw. Only one horn that I know of, two if you count my novelty klaxon. It wasn't me!
Post #333302 24th May 2014 7:58pm
munch90
think there should be two , one mounted to front headlight panel so it's in between indicator and side light and one up in top left hand corner as your looking at pic so really up beside rad but inside wing ( if that makes sense )
Post #333308 24th May 2014 8:09pm
ozzy57
I'll stick a meter on it and see if it powers up when I hit the horn switch. It wasn't me!
Post #333325 24th May 2014 9:33pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
AFAIK, Td5s are wired for two horns (Hi/Lo tones) but typically only have one (near side) fitted. I found my off side horn multiplug (purple/black trace + earth) tucked up in the offside inner wing (2005 110 SW)
As mentioned, the other two plugs are for the battery backed up alarm sounder (brown plug 4 black wires) and a non battery backed up siren (orange/black trace+earth).
From what I can work out, Td5s alarm sounder is the horn but in theory you can add both a BBUS & a non battery backed up siren in addition to perhaps a second horn.... that'll keep them guessing, particularly if some are fitted in non standard locations.
P38 part should work fine but worth checking how well the unit's battery holds its charge after all these years. Jon - 110 td5 [sold]. Currently Defenderless.
Post #333353 25th May 2014 12:00am
