Home > Td5 > struggling to get above 60mph
Page 2 of 3 <123>
bob neville
Have a read of this about the turbo actuator rod.
http://www.defender2.net/forum/topic13513....o+actuator
2013 Defender 90 CSW - sold
Post #332834 22nd May 2014 6:49pm
timtom1
United Kingdom 2001 Defender 90 Td5 CSW Alveston Red
wet and oily.. how do I fix this?
 2001 90 TD5 CSW Alveston Red Manual
Post #332839 22nd May 2014 7:22pm
bob neville
That does look bad Shocked
Have you pulled the red plug and looked inside, probably oil everywhere ?
First off you need a new injector harness, Alive (site sponsor) or BAS (site sponsor) will be able to sort that, can't remember the cost but less than £100. Don't get an ebay special !!! Probably worth getting the cam cover gasket as well.
Change the harness, sounds bad but actually very easy, Alive have a guide I think.
Once new harness is in place unplug the red plug and clean with electrical contact cleaner, get it as clean as you can. Plug back in and drive for a couple of days.
Repeat the cleaning process until no more residual oil coming through the red plug, it may take weeks.
Don't expect immediate results, you have got to get the residual oil out of the main harness.
Post #332842 22nd May 2014 7:45pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
There's your problem, new harness is about £35ish took me about an hour to change when I did mine, should be loads of info on here about it, if you're not confident about doing it an Indy should only charge about an hours labour,
As previously stated remove red plug every few days or so and re-clean until it stops coming through. Did mine two years ago and been fine since. 2005 Td5 90 XS
Steve
Post #332844 22nd May 2014 8:03pm
timtom1
ok, thank you gulp I will give it ago Very Happy Bow down
found one http://www.paddockspares.com/amr6103-injec...s-td5.html 2001 90 TD5 CSW Alveston Red Manual
Post #332848 22nd May 2014 8:12pm
bob neville
Good guide here
http://forums.lr4x4.com/index.php?showtopic=42788
I didn't disconnect the battery, not 100% sure why they did that ?
Make sure you get the correct harness and gasket for your engine, MY2002 onwards is a 15P engine and pre MY2002 is 10P engine.
That looks a bit like a s***part loom Shocked Give Pete at BAS a ring or Gary at Alive, either will sort you out with a quality item at a reasonable cost.
Post #332851 22nd May 2014 8:24pm
timtom1
is this something that's happened months back do you think? although it was driving fine until recently. 2001 90 TD5 CSW Alveston Red Manual
Post #332858 22nd May 2014 8:41pm
bob neville
Let's put it this way, with the oil in the seat box there is a lot of oil seeping through the loom and it has probably been going on for a long time. The problem is with this issue is that it can leak oil down the loom for a long period without any symptoms and then suddenly you have a problem.
I changed my loom last year with an Alive loom but still check it every couple of months just in case.
If you were closer I would say drop round and I will change it for you but Lancashire is a bit of a drive from Somerset !
To put your mind at rest, this is a known issue with TD5's, Defenders and Disco's, so you are not alone !
Post #332862 22nd May 2014 8:49pm
landy andy
Check arm to turbo actuator is free moving
Andy
Post #332863 22nd May 2014 8:57pm
timtom1
thanks its still under warranty so see how I get on. I've had it two weeks. 2001 90 TD5 CSW Alveston Red Manual
Post #332865 22nd May 2014 9:02pm
bob neville
If it's under warranty then get it back to the dealer. If the dealer sells Defenders I bet they cleaned the ECU plug to stop the immediate issue and hoped it would last out of warranty, stupid really as they were looking at less than £100 to sort it out. Non LR dealer would probably not be aware to the issue.
If the dealer sorts it for you insist on a quality loom. Not sure how they will sort the residual oil problem.
As an aside, I have a 2001 TD5 CSW and a 2013 90 CSW. Smiles per mile the TD5 wins hands down Thumbs Up
Post #332868 22nd May 2014 9:09pm
timtom1
he wasn't a specific land rover dealer, I bought it in the Cotswolds apart from that I love it 2001 90 TD5 CSW Alveston Red Manual
Post #332869 22nd May 2014 9:13pm
bob neville
He was probably not aware of the issue then - maybe the person who sold it on did a bodge to make it run OK ?
Cotswolds is a bit of a drive for you to get the harness replaced and the residual problem sorted. If I were in your situation I think I would have a word with them and explain the problem and that you know the solution and then see what they have to say. If you drive down and have the harness replaced you are still faced with checking the plug every couple of days until the oil has cleared.
I am sure you can get it sorted with the dealer - if you have to drive back to the Cotswolds you may as well do the extra miles and come to Somerset and I will do it for you !
When it is running properly you will love it even more - there is nothing better than a TD5 when it is running well in my opinion Thumbs Up
Post #332873 22nd May 2014 9:31pm
timtom1
cheers Bob I will see how I get on thanks to you all for the help Thumbs Up 2001 90 TD5 CSW Alveston Red Manual
Post #332875 22nd May 2014 9:33pm
excossack
I had the same issue you have, oil in the loom/red plug. I took the plunge and replaced it myself. Its not a hard job just take your time and work out where things go, the route of the cable etc.
If you do it, dont drop the little clips that hold the plug to the injectors.
Also, as mentioned worth getting a new rocker gasket as well.
As for the oil in the rest of the loom, there was'nt much I could do about it. so I left it. Cleaned the red plug every week or so until it stopped appearing 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #332877 22nd May 2014 9:37pm
Page 2 of 3 <123>
