![]() | Home > Td5 > What is the new bit on the back of my 10P 2001 TD5? |
90dv Member Since: 29 Jun 2011 Location: Cumbria Posts: 39 ![]() ![]() ![]() |
Looks like a fuel pressure regulator to me!
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Yup looks like a nice shiny new FPR
![]() Steve |
Duffs Member Since: 19 Apr 2014 Location: Northumbria/ Cumbria/ Borders Posts: 48 ![]() ![]() |
Cheers chaps. Are they expensive to buy and fit? 2001 DEF TD5 County
more MPG and lest diesel smell
New genuine parts FPR is about £150ish to buy and about 1hr to fit. 2005 Td5 90 XS
Steve |
Cheers for the replies and a thanks to the previous owner then.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218 ![]() ![]() ![]() |
It also stops diesel from leaking down onto the join between the engine and the bellhousing, and then causing the clutch to slip....
I thought it was designed to leak at a predetermined mileage so it would lubricate the the spigot bush when it got noisy ! 2005 Td5 90 XS
Steve |
Interesting, as getting clutch slip in 4 /5th when I give her some welly. I may now have a badly fitted new part! They certainly keep you busy. Thanks again for the advice, even if it adds another few hours to the list. ![]() |
If you've not long bought the motor I'd say just hang fire for a while, give the area round the back of the engine a good wash off with some degreaser, get all the carp off around where the new part has been fitted. You might find the previous owner has done the hard work and you just need to let the clutch wear off the contamination(with luck)by itself before you start changing bits for the sake of it.
Seems to be getting better, as you say, might be burning it off and if I don't need to pull her apart I won't
110MGD Member Since: 17 Oct 2013 Location: Wear Valley Posts: 153 ![]() ![]() |
Good news if its getting better
![]() 2016 E220 CDI Night Edition Estate 2014 VW UP! 2x D3 and 1x D4 GONE |
