Home > Td5 > Air intake position
Fullfat
1999 Defender 90 Td5 HT Rioja Red
Air intake position
May be a daft question, I am looking for new wing and side air intake vents but seem a bit confused, my side vent is on the left hand wing, but kbx site indicates td5 is on the right wing, it lists a 200tdi as on the left wing. My defender is a 1999 td5. Chassis vin lists it as a 2000 model.
Thanks
Post #332643 21st May 2014 10:19pm
excossack
Air intake for the air filter box or for the heater?
Heater intake is on the passenger side wing top
Air intake is on the drivers side wing, on the side
The above is based on a RHD Defender 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #332649 21st May 2014 10:22pm
Fullfat
It the intake for the heater I think, on left side mine is rhd.
Post #332650 21st May 2014 10:23pm
excossack
Have you got a link for the item you are looking at? 1999 Defender TD5 110
Regards
John M0VAZ
Post #332653 21st May 2014 10:24pm
Fullfat
Post #332654 21st May 2014 10:24pm
excossack
Regards
John M0VAZ
Post #332661 21st May 2014 10:28pm
Fullfat
It may be my wing has been replaced with a wing from a tdi200 model, does your td5 have any side vent ?
Post #332663 21st May 2014 10:30pm
excossack
That could be so. The only side vent I have is the air intake on the drivers side 1999 Defender TD5 110
Regards
John M0VAZ
Post #332664 21st May 2014 10:31pm
Fullfat
That's what is confusing me, I have no intake vent on the right hand side, so what isn't connected? Air intake ? Or does it not matter? Told you I was confused!!
Post #332665 21st May 2014 10:34pm
excossack
Maybe a picture of your engine bay around the air filter housing might shed some light? 1999 Defender TD5 110
Regards
John M0VAZ
Post #332706 22nd May 2014 8:34am
Are you sure it's a TD5 (serious question)? It looks like a Tdi.
Perhaps a TD5 engine has been retro-fitted to a Tdi vehicle, or the front end of a TD5 has been rebuilt with Tdi panels.
If you can post a photo with the bonnet open, preferably showing the areas inside the wings, it may be possible to advise further.
Post #332749 22nd May 2014 11:23am
excossack
Assuming its the same V reg vehicle as posted above it should be a TD5? 1999 Defender TD5 110
Regards
John M0VAZ
Post #332751 22nd May 2014 11:26am
Fullfat
Yes same one I checked the vin and it is td5 I'm guessing it's had its wings changed in a previous life, will take photo Friday when back home, as I need to see that all is connected correctly.
Cheers all
Post #332757 22nd May 2014 11:43am
Which rather begs the question where is the air intake for the engine?
Post #332763 22nd May 2014 12:39pm
Agreed, but I was thinking it mught be a pre-TD5 registered late, such as on cast from MoD.
Post #332764 22nd May 2014 12:40pm
