![]() | Home > Puma (Tdci) > TDCI 2.4 Fuel Tank Connections |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
Hi
I believe that the 2.4 puma and later 300tdi (ROW spec) have the same fuel tank sender unit. So you could convert your 300tdi to LR standard with the later fuel lines. They are expensive but it would be a good solution. I also seem to remember that the sender unit has an arrow indicating the direction of flow of the fuel. If not remove the unit and see which one is the fuel pick up. If the sender units are the same then the later loom would also have the correct connector but you can adapt the existing loom. The connector plug looks like a 300tdi indicator light plug but has more terminals so I think you could source this four pin plug and terminals and connect the wires. Hope this helps. 1995 300tdi Defender 90 P/UP 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
