Home > Maintenance & Modifications > Towing Electrics
Page 2 of 2 <12
Zouritte
France 2010 Defender 110 Puma 2.4 SW Java Black
hi,
Regarding the plug, is it fitted on all Defender (TD4), i'm going to fit one of those electrical plug to be able to tow a trailer. If it is, where should i find it? If not, where should i make a puncture on the harness ?
Thank for your help
Tim
Post #332291 20th May 2014 2:33pm
scotia
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Can anyone tell me the part number for the tow electric 12n wiring kit for a my15 110 please?
Post #372518 18th Nov 2014 7:08pm
blackwolf wrote:
Depsite being designed for the purpose, I have never seen a factory fitted or dealer fitted socket in the recess!
I can't understand why if LR designed this hole for this purpose they didn't amend the fitting instructions for the towing electrics kit accordingly.
I thought the smaller hole through the centre was a necessary access hole to reach a bolt for the fuel tank or something?
Post #372709 19th Nov 2014 11:48am
Martin
Site Admin
Land Rover accessories site has the part numbers: http://accessories.landrover.com/gb/en/def...ng/towing/
Dan @ Duckworths (site sponsor) will supply at a good discount: duckworthparts <- click me  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #372722 19th Nov 2014 12:41pm
scotia
Thanks for that information Martin and in particular regarding Duckworth prices.
Post #372751 19th Nov 2014 3:38pm
pmason1973
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Santorini Black
Jammer600 wrote:
Spent all Mornin cleaning my truck, thought I'd have a quick look for the tow elecs, found them, had a dig around in the wheel arch and found a plug here
So decided I'd un plug pull wires through and relocate here
Jammer600, it looks great. How did you attached the plug to the cross member? Thanks, Paul
Post #998898 6th Jul 2023 2:46pm
The easiest way is to install some rivnuts:
You can see how I did mine here: https://www.defender2.net/forum/post879215.html#879215 Darren
Post #998902 6th Jul 2023 2:51pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
https://irbdevelopments.com/
These guys do a plate that only needs 2 fixings to get it on then the electrics bolts to that. Wanted one when I fitted mine but could not get it in time. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #998938 6th Jul 2023 6:05pm
To be honest, that seems like complete overkill (and expensive) for what is a pretty easy installation anyway Darren
Post #998978 6th Jul 2023 10:34pm
pmason1973
My tow electrics have been taken off and I can't find where the plug is in the wheel arch to re-attach. Can anyone point me in the right direction, is it in the rear drivers side wheel arch? Many thanks, Paul
Post #999051 7th Jul 2023 12:52pm
Norfolk-n-chance
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Paul
Yes, the socket is at the top slightly towards the back of the drivers side rear wheel arch. Under a flap.
I can’t remember if you fold the flap or have to remove it…..
Someone will know.. “a committee is a group of people who individually can do nothing, but as a group decide nothing can be done.”
Post #999063 7th Jul 2023 1:40pm
The flap is a piece of stiff plastic and is designed to protect the back of the lights from wheel spray. It's held in place with a couple of screws into spire nuts, both of which tend to rust solid unfortunately. It's common to have to drill them out and if you do, then replace them with something made of stainless.
This picture is of the other side with the flap removed but you can see the fixing points along the top edge:
 Darren
Post #999328 9th Jul 2023 3:16pm
Page 2 of 2 <12
