Home > Maintenance & Modifications > Rear door/wheel rattle
Potter
United Kingdom 2013 Defender 90 Puma 2.2 HT Stornoway Grey
Hi folks,
My tdci 90 has only done 5k miles and a rattle has recently started from the spare wheel on the back door.
The car came with steel wheels so I had to use some spacers to space the wheel away from the rear wiper after I put the boost alloys on myself (I figured out it was too close the hard way and the rear wiper stuck!).
What is the official Land Rover way of spacing a boost alloy on the rear carrier and does anyone know what actually is rattling as the wheel nuts are tight on the carrier.
Many thanks
Post #332275 20th May 2014 12:45pm
redhandluke
United Kingdom 2003 Defender 90 Td5 SW Fuji White
I'll check for you later, but I don't think there's any spacers on mine and the wiper wotks fine. No doubt somone will give you a more definitive answer Thumbs Up
Steve
Post #332279 20th May 2014 1:04pm
Potter
Is it a different wiper or is it bent maybe?
Post #332289 20th May 2014 1:31pm
K9F
The studs on the carrier are adjustable to a degree! You should be able to wind them out sufficiently for a boost.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #332300 20th May 2014 2:16pm
Potter
Cheers but I'm not sure how moving the studs out are going to space it away from the wiper though? The back of the wheel sits against the carrier...?
Post #332303 20th May 2014 2:25pm
K9F
I shall say it again....The studs are adjustable. Look at the picture below. The flat nut will wind out allowing you to space the wheel away from the wiper without the need for spacers. The wheel sits against the nuts NOT the carrier. I removed one from the stud to show you.
Thumbs Up
Post #332306 20th May 2014 2:43pm
Potter
Cheers for that!
I don't have the flat nuts on mine... anyone know a part number?
Post #332540 21st May 2014 2:34pm
Potter
Anyone know the part number or point me in the right direction for the flat nuts?
Post #334261 28th May 2014 9:36pm
leeds
Your choices are using the standard steel wheel nuts on the studs. OK does not give such a large bearing surface as the flat ones.
Have no idea about part number but I know Safari Equip makes them for their wheel carriers. You can either phone them direct on 01274 835500, ask for Tom. Or I could pick up a set for you next time I am at te factory.
Please note these are not cheap as they have to be cut out of flat sheet, threaded individually etc etc.
Since your 90 has only done 5k miles how about asking your dealer for a set?
Brendan
Post #334270 28th May 2014 9:55pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
How about using some large flat washers to space the wheel away from the door,simple and cheap. 2005 Td5 90 XS
Steve
Post #334277 28th May 2014 10:27pm
Potter
I've actually got some standard wheel nuts from the steel wheels behind the wheel and then the boost nuts... but something is still rattling.
Could it be something else rattling? Like the door latch? Can the door latch be adjusted?
Thanks for your help guys
Post #334325 29th May 2014 8:16am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Yes you can adjust the door latch and make the door shut tighter, but only a small amount. Loosen the torx screws on the latch and movbe it in a bit. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #334326 29th May 2014 8:20am
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
I'm amazed you managed 5k miles before something started to rattle Laughing
if you're planning on keeping it long term it would be worth looking into a wheel carrier of some sort. The standard one on the door is only really for the steel wheels, since a Boost is significantly heavier you'll warp the door, damage the hinges / latch and eventually the back window will randomly smash one day... that's what mine did!
Post #334351 29th May 2014 10:33am
