Home > Maintenance & Modifications > Chequer plate wingtops - fit with gasket or not?
pob1968
Hi, I have had a quick search through old posts but....... I have 3 mm Black chequer plate to fit on my wings, I have no gaskets with them, I can make some out of some foam but is it best without? If you fit foam under the chequer plate are you not allowing moisture to be there longer? Do they squeak if gaskets are not used?
I hate rivnuts so got Black painted aluminum rivets to use. If they ever have to be removed I can just drill the rivets out and re-fit with new ones anyway. 110 Hardtop
Post #332256 20th May 2014 12:23pm
gilarion
I fitted mine without the foam and they have been fine. have you thought of fitting the plates with stainless steel fasteners with countersunk heads in my opinion they look so much neater, you could paint the tops of the fasteners black.
Post #332258 20th May 2014 12:32pm
K9F
Go to a garden centre that provides a marine service like Maidenhead Aqautics and buy a metre or so of butyl pondliner. This makes an absolute ideal gasket. My chequer plate is fitted with gaskets all of them supplied by the relevant suppliers. On everything else I have used pondliner to great effect.
K9F wrote:
I always use gasket it stops the crud from accumilating behind it. When I fitted the Entreq door strips I had to remove the sill chequerplate that didn't have any gasket. I was amazed at the 'dirt gasket' behind it and used a wallpaper scraper to remove the initial build up. I used butyl pondliner I had left over to make some gaskets before refitting. The bonnet I used the gaskets supplied and sealed up using black Sikaflex on the rest.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #332260 20th May 2014 12:38pm
landy andy
No point in fitting it. Water gets in a knackers wings any way.
Andy.
Post #332272 20th May 2014 1:41pm
K9F
What gaskets or chequerplate? If done correctly with gasket and wet assembly of the fasteners your comment is 'rot' in itself! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #332301 20th May 2014 3:20pm
pob1968
Ok fitted with pond liner under it. I also put grease in the holes prior to rivetting. Thanks for the advice much appreciated. 110 Hardtop
Post #332341 20th May 2014 6:19pm
gilarion
Just out of interest and I hope not sounding to daft but what does the foam actually do and what is 'wet assembly'
Post #332361 20th May 2014 7:01pm
Grouse
I hate tread plate, but if I was fitting it I would paint both surfaces in waxoyl - if you have seen the mess after tread plate is removed the reasons why are humblingly honest
Post #332370 20th May 2014 7:24pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
I would and have fitted mine with the foam provided.
I never noticed any issues when fitted 2004 TD5 Defender 90 xs station wagon
Post #332405 20th May 2014 8:37pm
K9F
Gaskets when compressed will prevent the ingress of dirt and moisture and prevent the possibility of corrosion and abrasion. Wet assembly is when you fit a fastener it is smothered in sealant or an anti corrosion medium, the excess is wiped away after tightening. This can give an effective seal and prevent the onset of dissimilar metal corrosion through the electrolytic interaction of two different metals when wet. You did ask!
Cool If you go through life with your head in the sand....all people will see is an ar5e!!
Post #332423 20th May 2014 9:12pm
