Home > Puma (Tdci) > Idle Jack
Smurph
2012 Defender 110 Puma 2.2 SW Keswick Green
Idle Jack
Can anyone tell me how to disable the idle jack? vehicle is 2012, 110.
Post #332049 19th May 2014 2:45pm
110 John
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Orkney Grey
Dont think it is possible to do that
Post #332056 19th May 2014 3:12pm
As a matter of interest, why would you want to?
Post #332060 19th May 2014 3:29pm
Smurph
I rather control the revs myself
Post #332227 20th May 2014 9:42am
Smurph
Can be done. Simply disconnect plug on top of transfer box.... much better
Post #338683 17th Jun 2014 10:12am
Phil_D
Smurph, which plug did you disconnect?
Phil.
Post #338728 17th Jun 2014 2:07pm
Smurph
Grey plug with a connection to the the area around the centre diff. There is another more important looking connection to the main gearbox. As far as I can tell there is no difference in the vehicles behavior except that the idle speed doesn't change automatically when in low range.
Post #338921 18th Jun 2014 8:49am
Phil_D
Thanks, I'll experiment with that!
Phil.
Post #338922 18th Jun 2014 8:50am
roel
I don't understand why you want to do it as I think it's the only improvement from an td5. Laughing
But yes by disconnecting the plug the ecu doesn't know you are in low gear so will not use the anti stall mode.
You can't do this anymore then:
https://www.youtube.com/watch?v=0jhuKLrjJLg&feature=related
just after 1 minute Roel
2003 90 Td5 (2009-now)
Post #338935 18th Jun 2014 10:25am
It won't affect the anti-stall at all, just the idle jack, which is a totally different and independent thing.
Idle jack is a safety feature to prevent you coming a cropper on very steep descents, where the very low 1st or reverse gear will cause loss of traction. I have to admit I still don't understand why anyone would want to disable it, but the method described above will do just that.
Post #339010 18th Jun 2014 6:54pm
