Home > In Car Electronics > cat 5e cables....rca
Caterham
Hi
Can anyone tell me why I shouldn’t use some cat5e cable to make up some phono / rca leads for my sub?
If ok should I simply use half of the inner cores for the outer part of plug and other half for the inner part of plug?
Post #331427 16th May 2014 8:47pm
munch90
why make them , you can get them in all lengths anyway
Post #331429 16th May 2014 8:56pm
Caterham
Have bought 2 pairs already and both wrong (either too short or too large diameter)
Have cat5e cable and as such could have installed this weekend and put plugs on after.
Post #331442 16th May 2014 9:48pm
Cupboard
You shouldn't make them out of CAT 5 because it isn't shielded. You can use it for balanced audio.
Post #331444 16th May 2014 9:53pm
munch90
not sure if it would work , maybe you would get interference , doesnt the outside of the phono lead act as a shield
Post #331445 16th May 2014 9:54pm
Caterham
Damn drat and blast.......but thanks all the same for the info.
Post #331448 16th May 2014 10:07pm
munch90
on maplin website you can buy the cable by the metre and the phono plugs to make your own up
Post #331455 16th May 2014 10:26pm
You need screened cables which cat5 won't be, if your unsure about cable length just get longer.
Thumbs Up
Post #331463 16th May 2014 10:39pm
Caterham
Many thanks. Maplin will be getting a visit today.
Thumbs Up
Post #331497 17th May 2014 7:04am
Cupboard
if you don't want to travel then cpc.co.uk is a good bet.
Post #331548 17th May 2014 12:25pm
K9F
CPC is indeed very good but you have to wait until delivery time. Caterham go to Maplins and get the job done, hope and pray it goes well for you. If not can we excpect the usual deluge of ensuing '5h1t I've got issues' posts?
Laughing Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #331552 17th May 2014 12:59pm
Caterham
Didn't get to Maplin today but if they're open tomorrow........
Sooner I get the cables sooner something can go wrong! Laughing
- car is going to be off the road for a week so perhaps there’s no rush after all?
Post #331638 17th May 2014 8:31pm
I use cat5 on some of our jukeboxes at work for phono signal supply (And on some CCTV)
The manufacturers even show a diagram of how to use the cable so some cores are the "screen" and one or 2 are the hot "signal".
I've never experienced any interference when doing this, even with cables stapled around pubs past lights/mains cables/beer coolers etc. I usually just pick a colour (usually the orange, as it's easy to remember and nearly red) then use the remaining 7 cores twisted together as a shield.
Caterham.... if you want some single core HD phono cable, i've got a huge (100m) drum of it at wotk, I'll gladly cut some off and post it to you.
Need phono plugs glued on the end? PM me the details and I'll knock some up.
Post #332131 19th May 2014 9:23pm
Blacktt600
England 2008 Defender 110 Puma 2.4 XS CSW Cairns Blue
Hi, excuse my ignorance but why use cat 5 cable for phono? Surely it's too thin?
Martin
Post #332144 19th May 2014 10:07pm
Caterham
because I have some in the garage Very Happy
maybe its too thin maybe not......its good for data transmission upto circa 100m so I'd have thought 8m of audio signal would be ok?
far question all the same Thumbs Up
Post #332149 19th May 2014 10:13pm
