Home > Td5 > Immobiliser/alarm problem
Mac87
Hi -this ones driving me mental
Locked the landy with the keyfob, went and had some lunch, came back and the keyfob wouldn't do anything. Opened it with the key and rather than working the central locking it only opened the drivers door. As soon as the ignition is turned on the alarm goes off with the engine light with the lightning bolt through it flashing.
Have tried to manually put in the EKA code but doesn't seem to have worked. Changed the keyfob battery and checked car battery but no change.
Any ideas gratefully received - it's stuck out in the middle of a field
Post #331231 15th May 2014 3:58pm
Disconnect the battery completely for a while then reconnect (ten 15 mins) try it then, worth a go.
Post #331235 15th May 2014 4:35pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
There is a synchronisation process to carry out after changing key fob battery should be in the hand book if you have that with you. 2005 Td5 90 XS
Steve
Post #331236 15th May 2014 4:38pm
Lou Sparts
Just looked in my hand book it says to press padlock symbol at least four times within range of the car to synchronise fob after changing battery in fob. 2005 Td5 90 XS
Steve
Post #331238 15th May 2014 4:49pm
Mac87
Result - Just before going for the Basil Fawlty, beating with a branch trick, had a look under the seat and the fuse for the central locking was certainly blown, the immobilizer ones looked alright but slightly blackened. Had a swap round and she fired up, which is the main thing! Although key fob still doesn't work, and it keeps blowing the central locking fuse but at least shes home.
Post #331242 15th May 2014 5:22pm
Lou Sparts
I'm going to nominate for an award Mac, for being "outstanding in your field" Whistle 2005 Td5 90 XS
Steve
Post #331247 15th May 2014 5:32pm
JWL
Just check the wiring from the door pillars to the doors, it may be a couple of broken wires shorting out and blowing the fuse when you activate the locks.
Post #331252 15th May 2014 6:02pm
I agree with above, seems a bit like that might well be likely.
Post #331253 15th May 2014 6:12pm
Mac87
Cheers chaps will check that out. I did look like a bit of a lemon ranting at my Landy, still, only took me 5 hours to figure it out Embarassed
Post #331257 15th May 2014 6:38pm
Mac87
Checked the wiring to the drivers door, sure enough a broken wire. All put back together and central locking works a dream. Thumbs Up
Post #331380 16th May 2014 3:50pm
