![]() | Home > Maintenance & Modifications > Utility Wagon Loadspace Liners |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5981 ![]() ![]() |
I brought heavy duty chequer plate rubber mat from Drew Wright at Wright off road.
![]() Click image to enlarge Andy |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
That looks quite good I like that.
Thinking that up to the top of the tub then ply lined with some kind of hard wearing fabric for sides up to the roof. |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861 ![]() ![]() |
Costco do a garage floor rubber liner that would do that.
Stable mat. Cheap, hard wearing and being relatively heavy will stop drumming and a fair bit of noise. Steve.
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
I fitted a Land Rover 90 Genuine rear one piece mat. Fits to shape, one piece and easy to sweep out. Just had to trim the rubber to fit fuel filler housing as its in a different position in 110.
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2666 ![]() ![]() ![]() |
Noisekiller next to the metal on the base, dynamat on the sides and inside the back door panel, TGE panels, and a Nakatenanga loadspace mat (oh and a gas strut to hold the door open
![]() ![]() Click image to enlarge (Gas strut was fitted after picture taken) Lovely & quiet in the back now ![]() |
Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 672 ![]() ![]() ![]() |
Any, what did I you use to stick the rubber matting up the sides of the rear tub? Also, where did you get the metal retaining strip? Just bought the same thing and want to do similar. Thanks Ian |
