![]() | Home > Maintenance & Modifications > Blackvue dashcam install |
I put one in the D4 with the Power Magic controller hardwired in. Well, I say I did...I got an auto sparky to do it, it was much easier! An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20974 ![]() ![]() |
Avoidance tactics Pete.
![]() What connections does the blackvue have? |
It comes with a fag lighter!
This is the Power Magic which controls it when ignition is off: http://www.blackvue.co.uk/index.php/online...ler-detail An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
That doesn't give much info really, voltage details etc are just to differentiate between engine on approx 14.2v (est) with alternator charging or 12.2v (est) at rest.
So full power draw with engine running, engine and ignition off it will run a preselected time after then turn off. I would imagine it'll be a ground / earth, constant fused live and ignition switched live. |
If it's voltage sensitive it might not even need ignition just constant live.
Its a three wire system perm ig+ and neg
Thought it might be.
![]() I'd be interested but a bit spendy for now. |
