![]() | Home > Maintenance & Modifications > Post 2007 dash |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 ![]() ![]() |
Think killers in the middle of doing one
![]() DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
Wouldn't it be very hard to change gear?
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
It's not easy
![]() Gearstick,fuse box and heater is the biggest problem everything else is ok ![]() ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Wangers Member Since: 19 Jan 2013 Location: West London Posts: 265 ![]() ![]() ![]() |
how mcuh for a convertion killer? Ball park as been tempted for a while and if you're doing one, you can always do a second.....
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2762 ![]() ![]() |
There's also the issue of the gauges/instruments. Tdci uses CANBUS which no previous Defender has, so in order to use the later instruments you would have to add a CANBUS system via some sort of controller that could read the parameters and feed them to the gauges. The easier option is to remove the later gauges and put a set of Td5 ones in their place, this is what I would do.
Gearstick could be solved by bending it as above or maybe by changing for a Discovery gearbox which I think might put the levers further back (ie. halfway into the seatbox). You'd have to do a bit of cutting about. |
What puddle? Member Since: 25 Oct 2013 Location: Reading Posts: 952 ![]() ![]() |
Retro, very informative, thanks. Think I might give that idea a miss then. Now left.
IMO best off with a td5 late dash fits lovely and works perfectly
![]() Rough figure is about £1500 matey ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
I have thought about doing the opposite and fitting a td5 dash with vents in a new tdci but thought I would just get a td5
