Home > Maintenance & Modifications > Does anyone have a steering wheel puller I could borrow?
Green Machine
Trying to get the steering wheel off my Td5, but it really, REALLY does not want to come off! I've doused it in PlusGas, left it for half an hour, whacked it from every possible direction, yanked it as hard as I possibly can without injuring myself and it will not budge. I could just buy one off eBay, but it's one of those things that you only really need once!
So if anyone has one that they'd be willing to post to me, and I can then post back once I've used it?
Ta.
Tris. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #330220 11th May 2014 2:11pm
excossack
My method was to undo the nut so it almost off, and then from behind hit the wheel at 12 o'clock 12:30 and quarter to and quarter past and then repeated then work backwards quarter to, 12:45 , 12:30 12:15 etc.
Sorry no puller Sad 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #330231 11th May 2014 3:10pm
Killer90
Site Sponsor
Tris I got one here I made. Very simple mate more than willing to post it tommorow for you Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #330233 11th May 2014 3:15pm
Green Machine
excossack - thanks for the suggestion, but I've tried and tried 'til I'm blue in the face and it just won't budge at all.
Chris - you have a PM - thanks Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #330238 11th May 2014 3:31pm
excossack
FBH ?
Good luck! 1999 Defender TD5 110
Regards
John M0VAZ
Post #330242 11th May 2014 3:43pm
LR90XS2011
Have you tried getting someone to pull the wheel towards the interior and giving the shaft a smart hit in the opposite direction? (avoiding damaging the treads or anything else I would use an alloy or copper drift in the centre of the shaft when I did this) DEFENDER 90 TDCI XS,
Post #330258 11th May 2014 4:36pm
munch90
maybe you tried this already
loosen nut but leave on few thread , sit in drivers seat put hands each side of wheel and with your weight pulling on the wheel , rock the wheel from side to side (not turning the wheel )
so weight of pull lifting you out of seat is on one side then the other
straighter your arms are the better (not so easy in a defender to get your arms straight )
Post #330261 11th May 2014 4:45pm
Grey110
Netherlands
This summer I bought a new steering wheel and to be sure I had the right steering boss I changed the steering wheel in the parking lot.
First loosen the nut as much as possible but leave it on. As a tool I used two bolts and two big washers to pull on the steering wheel. Tighten, pull a bit and thighten more etc. Martin
Previous 2003 Defender 110 Hardtop TD5
2004 Defender 110 Station Wagon TD5 - Libyan Sand
2005 Discovery 3 - V8 - Black
Post #330347 11th May 2014 8:05pm
