Home > Maintenance & Modifications > Puma glove box
Page 3 of 4 <1234>
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Jim_Bean wrote:
mark_d i really want to get the same result as you - looks superb Bow down
What fixings are those on the dash?
Hi Jim,
I've detailed the work in my blog. This is the link: http://defender90xs.blogspot.co.uk/2014/05...ation.html
It took quite a bit of modification to get the result:
The fixings to attach the lid are the original torx bolts shortened with the plastic captive nuts being modified and re-used.
The lower metal plate was removed from the hinge assembly to reduce the height by a mm or so. This was done by breaking the spot welds (x5).
The hinge is attached to the dash with pop rivets. http://defender90xs.blogspot.co.uk/
Post #329530 9th May 2014 6:27am
Jim_Bean
Wow mark - thats a great blog. I've just been reading through some of your other mods.
I wish i had the patience, skills, tools and know how! Love the hand brake mod as well Bow down
As far as the glove box goes i'll try some flatter headed screws and removing the honeycomb pattern to lower the lid. Failing that i think i'll get rid of it.
Love the idea of the glove box but 'out of the box' the Mobile Storage/MUD one just doesn't look right.
Post #329565 9th May 2014 9:15am
Pickles
Mine just doesn't sit right
I would most definitely NOT be happy with that.
I like things to be like OE, which that is not.
So, if someone is intersted in this conversion, how can they be assured if they buy a "kit", that they are not going to end up with something that does not "fit"?
Pickles.
Post #329586 9th May 2014 10:32am
Jim_Bean
Don't buy the MSS/Mud one. I hear the Nakatenga version is better but have no experience of it myself.
mark_d's fix of the MSS version is fantastic. Shame it doesn't come packaged like this in the first place.
Post #329587 9th May 2014 10:36am
Pickles
Mark, I've looked at your installation "process". WELL DONE, you've done a really beautiful job, to achieve the O.E. look that you have. You'd have to be happy with how it looks & operates now. That is how it should've come from the manufacturer. Surely someone will eventually make a "correct one".
Pickles.
Post #329796 9th May 2014 10:59pm
K9F
They are all very similar, I have the Nakatanenga one and that too took a bit of fettling to get it right. The fixings for the lid were chromium too not black. May well have changed specification now as it was a long time ago I purchased mine. I know you shouldn't have to but if it doesn't fit 'make it fit.' I too if memory serves me correctly had to go for lower profile screws on the hinge to get the lid to sit right and it wasn't lined so things had a tendancy to rattle inside. I used an offcut of leather and lined it myself. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #329799 9th May 2014 11:30pm
Lorryman100
The one I have from Naka went straight on with no fettling required. It has been on a couple of years now and gives the other (better) half somewhere to store her bits and bobs.
It came with silver domed nuts on top and uses the original fixings to clip it in place so when its closed, its closed.
Post #329801 9th May 2014 11:41pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I fitted the Naka one but fitted clips back into the slots so that the pegs fit tight and it stops the lid bouncing open. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #329837 10th May 2014 10:00am
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
Fitted the First Four glove box following mark_d's instructions. Good stuff and great result, but I found that I have 1 missing metal clip to keep the lid closed. Anyone knows were I can buy a replacement? Thanks guys, ciao Smile
Post #334777 31st May 2014 1:23pm
Smilesapart
Ok so just to be clear, I'm about to buy one of these....,
So am I right to be getting the Nak one?
Can I get one in that make with the lid in leather to match my cubby box? See below.
And who offers the best deal?
Post #336245 6th Jun 2014 8:56pm
Take a look at our website - www.FCX.co.uk - we trim in leather in house and offer the Mobile Storage Systems glove box kit fitted to a dash top and trimmed in leather
Post #336283 6th Jun 2014 10:46pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
I have the leather trimmed glovebox, grab handle, dash top & extra thick cubby lid from FCX, the quality of the product is top notch, the attention to details is as good as I've seen on any of the top notch furniture we have supplied!!!
Would definitely recommend any of their range.
J
 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #336293 6th Jun 2014 11:20pm
Thank you Bow down
Our cubby lids are all custom made, the one above was specified with a plain top, we also supply with perforated leather stripes and Alcantara Thumbs Up
Post #336317 7th Jun 2014 8:19am
DSB
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Indus Silver
A great thread which helped me with my decision, and I was impressed with mark-d’s attention to detail with his fitting. I thought I would try the first four glove box kit, slightly more expensive than some but it looked like it would sit fairly flush. Quite easy to fit and with only a bit of fettling got it to close with a click and sit well. My wife didn’t notice anything different which was a good sign. I also lined it with the black anti slip matting, which also hid the marks left behind after removing the four plastic support flanges. All in all, very happy with it.
Steve
Post #336373 7th Jun 2014 1:15pm
Jeff 8
Australia 1998 Defender 110 300 Tdi SW Chawton White
I got the MUD glove box and am half way through fitting it. Unfortunately I dropped a flange nut while trying to fit the hinge on the drivers side, luckily there is another flange nut in the kit. But I am worried about the nut inside the dash, how do I get it out without removing the whole dash?
Also has anyone fitted a 12v plug inside the glovebox, like in a Transit?
Jeff
Cow
Post #425015 20th May 2015 9:11am
Page 3 of 4 <1234>
