![]() | Home > Td5 > Fitting new ancillary belt |
TD5_dan Member Since: 24 Feb 2012 Location: Essex Posts: 449 ![]() ![]() |
Takes about 10 mins, if you want to you can remove the fan cowl along top of rad panel note the route the belt takes move tensioner back and remove old belt. Fitting new one is just reverse oh and no need to remove viscous fan I would keep that in place on a td5
![]() 1970 Series 2A Station Wagon 1970 Series 2A hard top 1960 Series 2 1972 Series 3 |
DefenderJon Member Since: 01 Dec 2012 Location: Sunny Ulster Posts: 68 ![]() ![]() ![]() |
As above, definitely remove the plastic cowl. You'll also need a 15mm ring spanner to rotate the tensioner.
Quick and easy job. Jon. |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 ![]() ![]() ![]() |
Thanks for tips. When the wind dies down I will have a go!!
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5998 ![]() ![]() |
A tip I learnt was not to just release the auto tensioner, but to force it into the belt, it made mine quieter.
Andy |
Well its done but no thanks to LR
![]() I brought the belt from them and took me awhile to get the belt off (took it off underneath). Went to fit new belt but it didn't fit as it turns out they had given me a td5 discovery belt. Following a interesting conversation with the parts dept I re-fitted the old belt and collected the new. Fitting the new took 2omins and now all is well. One thing that caused me headache was getting the old belt back on but eventually worked out to slide it onto the viscous fan pully (once the rest was lined up) was the best way to get it on and it proved correct as the new one took 2omins. |
![]() ![]() 1970 Series 2A Station Wagon 1970 Series 2A hard top 1960 Series 2 1972 Series 3 |
Well ill try and beat the time of 20 mins when I next do it...in about another 90k
