Home > 130 > Advice from 130 owners please, plus restoration thread
Page 1 of 6 123456>
Rosso_NI
United Kingdom 1993 Defender 110 2.5 n/a Diesel ST Galway Green
Newbie to forum but not to Defenders Smile
Hello, I have recently bought a 130 Double Cab have owned a few 90s and 110s but this is first 130. This was an ex utility vehicle which had broken down and used by a dealer as a spare parts vehicle. I bought it from a friend who had started to upgrade it but basically a half finished project.
Problems started when i decided to move commercial looking dropside body to go for a more factory look and fit a hi cap body.
Land Rover only list one body mounting bracket which does not suit my 130 ! Panel gap between DC and HCPU is larger than expected, also have issue with rear overhang and bracket position.
Any advice will be much appreciated have tried to look at various photos online to see if i can find what i am looking for but no joy.
Shortage of 130s owners in my area please help
Will post pics of restoration as it evolves.
Post #329557 9th May 2014 8:45am
Rosso_NI
Could somebody please measure for me distance from rear cross member to rear lip of body and post pictures of rear brackets, would help a great deal.
Don't know whether this will be a factor or not but vehicle is 2003 where as hi cap body is off a 88/89 Turbo Diesel ?
Post #329559 9th May 2014 8:52am
SGH
Is the rear body you have of a 130 or 110 hi-capacity?
The 130 hi-capacity body is shorter than a 110
Post #329563 9th May 2014 9:07am
Rosso_NI
As far as i can understand yes its 130 as it has the shorter section in front of the rear wheels.
Post #329566 9th May 2014 9:16am
SGH
When it stops tipping it down with rain will attempt to take some pics of mine.
Post #329576 9th May 2014 10:00am
AndrewS
Post #329618 9th May 2014 1:08pm
Rosso_NI
Thanks AndrewS it looks like those brackets are different or have been modified compared to brackets listed by Land Rover which i think are MTC3481 and MTC3482
The rear cross member brackets are even more of a mystery, i have even considered the prospect that my rear chassis has been shortened but it doesn't appear to be. Maybe some dimensions would satisfy my curiosity.
Post #329621 9th May 2014 1:20pm
Rosso_NI
Just found this photo LR bracket has extra fin at the top compare to AndrewS brackets, could a possible solution be to grind this off to allow body to come forward, mind you the bolt hole pattern might not allow the travel.
Some serious head scratching going on Sad
Post #329626 9th May 2014 1:27pm
AndrewS
That bracket bolts to the underside of the tub (I think), the bracket that goes onto the chassis is bigger.
See below a couple of library pics I have.
NS
OS
Hang on a bit my lads are up my workshop and the are going to email a pic of the brackets fitted.
There should be about 10mm to 20mm between the back of the cab and the front of the tub.
Post #329654 9th May 2014 2:54pm
AndrewS
Does this help
Post #329659 9th May 2014 3:02pm
Rosso_NI
Yep it helps have taken similar photos of mine, brackets are different alright, although these seem to be only ones my dealer list
Although not clear at the top of this bracket (attached to chassis) there is like a sharks fin with a fold this is stopping the body coming forward
Your body seems to be mounted using bottom two wholes if i cut the fin above off it may let me use bottom two holes although i think this will put body to high against double cab.
Gap between Body and double cab is more like 40mm
Think i might need to replace brackets on hi cap body as these were existing may just be a problem with trying to match up an older bracket with a new type.
Have not even tried to understand rear cross member bracket problems yet Confused Might leave that for another day..........
Post #329672 9th May 2014 3:36pm
GUM97
Nice project! Thumbs Up An engine to TDi for!
Post #329690 9th May 2014 5:03pm
AndrewS
NS front tub mount. FYI the tub mounts are handed however they are both the same (well they are on my truck) So the 90 deg fold on the edge of the brackets on the chassis points to the NS whereas the fold on the tub brackets is towards the OS.
Rear X member
Post #329692 9th May 2014 5:04pm
Rosso_NI
Well thats a relief rear cross member to body is similar measurement especially if i can get body forward by 20 mm or so although the cross member brackets my local dealer have supplied are too shallow an angle and not long enough will photograph tomorrow
Thanks for you help will try and battle it out with dealers, have you guys any parts dealers or specialists you can recommend that know whats what when it come to 130s ?
Cheers Very Happy
Post #329703 9th May 2014 5:34pm
Rosso_NI
This appears to be a no brainer, but the rear x member bracket i have been supplied by dealer appears to be shorter and less of an angle, than brackets shown in AndrewS previous pictures.
As far as my local dealer are concerned ony one set of brackets is available for hi cap ? (This the case for front will double check rear brackets with them)
Post #329711 9th May 2014 6:13pm
Page 1 of 6 123456>
