![]() | Home > Puma (Tdci) > Transfer Box Oil |
epictrail Member Since: 21 Sep 2013 Location: High Wycombe Posts: 395 ![]() ![]() ![]() |
Ashcrofts said EP90 when I asked this question last week
Phil_D Member Since: 09 May 2014 Location: Perthshire Posts: 25 ![]() |
Thanks, do you know what quantity?
Phil. |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Fill it up till its coming out the top filler plug.
About 2.8ish liters. I usually buy 3 bottles from halfords and then have some spare to top up the axles ![]() |
Halfords has EP80W/90 GL-4 and GL-5: which one should I use?
Thanks, Phil. |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
http://www.commaoil.com/products
put your details into their, will give the right quantities and grades. As for the PUMA box, I'm pretty sure I've read that you shouldn't fill to the filler plug level like you do with the older trucks, so be careful |
Ah, so Comma recommends GL-4 for the axles and SX75W-90 GL-5 for the transfer box. I don't know the difference between GL-4 and GL-5 oils so I don't understand the significance. Why on earth doesn't Land Rover specify this in the workshop manual?
On the quantity point, I know the main gearbox isn't 'fill to level of plug' (it's 2.4ltrs dry and 2.2ltrs refill). The post above suggests the transfer box is 'fill to level of plug'. Phil. |
Diablo- Think that only applys to the Gearboxes not the transfer box but i could be incorrect there I'm sure someone will correct me!
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 ![]() ![]() |
AFAIK if there are bronze bushes in the diffs GL5 will eat them, whereas the GL4 won't. The SX75 is a synthetic I think. The use of GL4 or 5 is well debated when it comes to LR. |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2673 ![]() ![]() ![]() |
Refill to the level plug (2.4 litres). I used Fuchs Titan Race SYN 5 75W-90 Fully Synthetic Gear Oil (was Silkolene SYN 5 75w-90) - this one's GL5.
Tightening Torques: Transfer Box Filler: 30nm Transfer Box Drain Plug: 30nm. Manual says "API GL4 or GL5, MIL-L-2105 or MIL-L-2105B" Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Martin, hello, I just found another very helpful post by you about this. I copied your list of oils and checked the Opie website:
Castrol Magnatec 5W-30 A1 Fully Synthetic Engine Oil – 8 Litres Castrol Axle EPX 80W-90 – 5 Litres Fuchs Titan Race SYN 5 75W-90 Fully Synthetic Gear Oil – 3 Litres (Transfer Box, needs 2.3l) Castrol Syntrans Multivehicle 75W-90 Fully Synthetic MTF – 3 Litres (Gearbox needs 2.4l) It comes to £167.82, can that be right? Phil. |
yep - it's not cheap
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 ![]() ![]() ![]() |
I read somewhere you must nit fill it up till it comes out. I must only hold 2.2litres...???
What does the manual say? |
My copy of the workshop manual does not contain any information about the type or quantity of oil required for the transfer box. I saw a post by Martin which (I think) explains that the transfer box is to be filled to the level of the plug and that takes about 2.4ltrs.
In relation to the main gearbox, the workshop manual says capacity is 2.4ltrs from dry and 2.2ltrs refill. The main gearbox is to be filled or refilled with a measured quantity, not simply to the level of the plug. Phil. |
Found it: 2.3 litres: top of page 731
