Home > Maintenance & Modifications > Pro Comp Extreme Alloys
discocuzzy
Chaps,
Can any of you lot get these and ship to the uk?
http://www.quadratec.com/products/92819_27XX_A_PG.htm
Alex E had a similar set on his 110dc and thought they would look pretty good and different on my 110 Thumbs Up
By the way does anybody know what the stud pattern is for a 110? You cannot teach stupid people to do clever things
Post #12814 9th Jul 2009 10:44pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
I might be wrong but I think I saw those pro comp wheels on one of the john craddock adverts in the landie mags Exclamation
Post #12817 9th Jul 2009 11:46pm
discocuzzy
They dont do them anymore Big Cry You cannot teach stupid people to do clever things
Post #12828 10th Jul 2009 11:02am
Alex e
England 2006 Defender 110 Td5 DCPU Zambezi Silver
SOoooooo last season.... Rolling Eyes
you can also get 18" ones too....
Post #12829 10th Jul 2009 11:33am
MK
Re: Pro Comp Extreme Alloys
discocuzzy wrote:
Chaps,
Bolt pattern is 5 on 6.5. Puma 110" SW
Post #12834 10th Jul 2009 1:02pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
Hi All,
I know "Holy Thread Resurrection Batman" ...
However, I'm after some help.
I have a set of these wheels on a recently acquired 110 DC (but the cast black version), but there's a right royal mix of wheel nuts and one missing though found the spare, but I think the hub thread is damaged as it wont bite.
I'm trying to source a set of fresh nuts *cough* but really struggling. I have contacted Pro Comp and they say they don't do them! Rolling Eyes ... Well, they seem to be attached to my truck rather well if they don't!
Does anyone know anywhere I can source some? (Also tried Craddocks)
Or does anyone know the correct dimensions?
Obviously they'll run M16 x 1.5, but I cant be certain on the seat taper. I've very roughly measured the spare and I believe it to be 60*, but for M16, the most common taper is 80* with no where really having a 60* taper on that size.
I've found a source of U.S. Wheel nuts which fit the bill, but the tapered section doesn't half as meaty as the Pro Comp ones so not sure what to do. Plus I'm still not 100% on the taper degree. Is there a way to find on on the wheel, which taper it runs (Cant get my angle ruler in the hole)?
Many thanks in advance and sorry again for bringing back from the dead!
On a side note, does a 0 Offset really equal roughly 4.5" spacers :O!?
Post #329244 8th May 2014 11:38am
Leenorthants
F
Quadtech ship to the uk, I have had a steering damper sent for a wrangler.
Post #329386 8th May 2014 7:40pm
Grouse
@ taaz 00 offset is the same as a 33mm spacer - as std LR rims have 33 offset (Boost, Freestyle or std steels - Wolf are 20.8
Post #329389 8th May 2014 7:44pm
taazzukcb
Can't find any reference to a Quadtech unless about Quad Bikes :p!?
Do they have the right nuts?
Been talking to the Pro Comp guy again today and he's sure pro-comp never made the nuts for thye Defender so he says they must of been supplied by someone else. Summit Racing have a US Wheel, lug nut with the correct dimensions, they just dont look very solid. The taper is built into the Hex if you get me, unlike the ones I have now which had the tapered section, then cut down to the Hex, so look much stronger.
As to the offset, that's good to know! Always though standard was more, but now stand corrected Smile.
Post #329454 8th May 2014 9:38pm
K9F
Try these, if they don't have them they'll make them. Thumbs Up
http://www.wrington.co.uk/index.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #329489 8th May 2014 10:46pm
