Home > Td5 > Td5 alarm
Fullfat
1999 Defender 90 Td5 HT Rioja Red
Td5 alarm
Hi does a 1999 td5 pickup have fitted as standard an Engine immoblising devise, that immobilises the engine of the vehicle as my insurance agent put it!
Post #329435 8th May 2014 9:10pm
excossack
I know mine does.(of the same year) I have two ultrasonic sensors built into the plastic trim just above/behind the drivers head 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #329436 8th May 2014 9:16pm
kipperthedog
All TD5s have a Lucas AS10 ecu behind the instruments. Not all have it activated as alarm/immobilizer. To do this you need the steering column part, fobs and someone to plug it in to a computer to activate it. I can't remember how much I paid for this, but don't think it was too shocking.
Post #329554 9th May 2014 8:33am
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
When my insurance company were being awkward, the factory fitted immobiliser was not good enough for them as it was not thatcham cat 2 approved (I think it was cat 2).
To have a seperate one fitted at a local auto electrician was about £130 so it might not be worth upgrading the original if it needs it. 2002 110 td5
Post #329588 9th May 2014 10:39am
kipperthedog
My insurance company wouldn't either, but when I provided the underwriter with photographic evidence that it was the same system as that fitted to a Puma they accepted it. Bo the Puma and Disco 2 have Thatcham approval for this system, but not TD5 defender. It took some persitence to make this happen and the broker was having none of it, but I got there in the end!
Post #329610 9th May 2014 12:37pm
The Disco 2 system is totally different to any Defender systems and doesn't use a Lucas 10As unit.
I believe that the Disco 2 is Thatcham Cat 1 approved.
Post #329622 9th May 2014 1:21pm
kipperthedog
Bow down Late Disco1s have it not 2s quite right.
Post #329630 9th May 2014 1:47pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
Again, it's all easy to do and all the information is out there.
you need the
fob with the correct frequency 315 or 433 MHz
central door lock relay NEC EP2-3N1S (if your didn't come with alarm, i doubt it has cdl), you need to opne up the green box to solder this onto the PCBA and get wires 2 and 3 out from there to drive the CDL motors.
bonnet sensor switch (wiring already in the harness)
door switch and wire harness
transponder ring (wiring already in the harness)
utrasonic sensor (and wire harness)
back up battery sounder (you can use one from a P38 rangie.
You will need to know what options to turn on in the 10AS, so you will need a nanocom. The defender has migrated, leaving the owner behind.
Post #329708 9th May 2014 5:59pm
