![]() | Home > Puma (Tdci) > Roof Spot light recommendation ? |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2277 ![]() ![]() |
Good choice . Quality wins the day .
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 ![]() ![]() ![]() |
the pattern on the lens is very similar to the Hella Comet lights on the Tomb Raider
SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464 ![]() ![]() |
Lads I have a wire I got from eBay to wire 4 roof lights it says 55w x4 since the lights I have on the way are 100w ? 2016 Defender 90 Adventure Edition
Great thanks a lot, will try and do something similar to power all 4 lights with one button. 2016 Defender 90 Adventure Edition
Would it possible to have 2 Hella Wiring Harness power 4 aux lights lights within one switch button?
![]() to this ![]() |
Anyone can help me with the above question ? 2016 Defender 90 Adventure Edition
You will need to switch the lighting supply via a relay as the switch depicted will not cope with the current draw of your lights alone. Best practice is to switch the earth of the relay. Presumably the relays are supplied with the loom. If so the anwer to your question is a resounding YES! If you go through life with your head in the sand....all people will see is an ar5e!!
Matthew_Mills Member Since: 16 Feb 2014 Location: Somerset Posts: 152 ![]() ![]() |
Where can I get one of those switches? I need to replace dealer fitted rubbish for a work light and that will do the job...
stick a 40" or 50" light bar up there, lower power consumption and much better light
I don't like the look of those, more suited to american trucks. 2016 Defender 90 Adventure Edition
http://www.dingocroft.co.uk/acatalog/Electrical_Miscellany.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
![]() Click image to enlarge[/URL] AS BP said :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
Fifty quid for a switch? Got the heated seat switch on that site for £44 for £5 from Dan at Duckworth parts |
I have seen the light, honestly after fitting Nolden headlamps I have never thought one single upgrade would be strong Its Bi-LED so, high and low beam ![]() ![]() My Roof Rack lights will be Hella 4000 Halogen My Nudge Bar lights will be Hella 4000 Luminator LED Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
