Home > In Car Electronics > How long is a battery's life?
landy andy
How long do you think a defenders battery should last?
Think I might need to buy a new pair Big Cry Big Cry .
Do batteries have a shorter life if not fully worked?
Andy
Post #329166 7th May 2014 11:21pm
K9F
4-6 years I would say on previous experience. If 'worked hard' battery life will be reduced as the capacitance capability reduces and sludge/silt can build up in the bottom that can eventually short out a cell or two. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #329188 8th May 2014 5:56am
roel
Looks like the 'newer' models are more battery sensitive then the old ones. When my D3 didn't want to start on his old battery (5 years old) I tried it im my 90 td5 didn't start either. A few weeks later I tried it in an 1984 90 diesel and it started straight. Without charging in between.
Even after fully recharging and standing overnight it could not start my td5 but could start the old 90. Roel
2003 90 Td5 (2009-now)
Post #329200 8th May 2014 7:49am
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
My Td5 is still on its original battery at 9years old,but never had a battery last more than about five years before. 2005 Td5 90 XS
Steve
Post #329203 8th May 2014 8:00am
landy andy
Newer models are definitely more sensitive. Notice (as per earlier post) that voltage considerably drops as soon as I turn on the Tdci ignition. Never noticed this on my Td5, but thought was what Tdci's did. Yesterday decided just to operate the winch without engine running, and no load on, but battery lasted only a couple of mins. So think it's the batteries.
Any one got deals on oddesey batteries running?
Andy
Post #329207 8th May 2014 8:17am
jimbob7
I assume its coz there is so much more to power up on newer vehicles before you even start the engine,plus engines are higher compression with much tighter tolerances. Pov.spec,ftw. 2006, 110,TD5.
Post #329208 8th May 2014 8:29am
jav-uk
England 2014 Defender 110 Puma 2.2 SW Alpine White
Lots of factors affect battery life.
Have a look at www.ctek.com, they have some clever technology to recharge and maintain battery life.
I purchased one of their chargers for the father in law, he was well impressed. Paul
Pondering a New 90 Commercial
2020 Evoque
* 2014 110 SW JE Stage 2.
*2010 110 Utility. JE Stage 2.
*2007 110 SW
*2003 90 JE Stage 2.
*2000 90 SW
If its not leaking it ain't full.
Post #329209 8th May 2014 8:35am
My original (Delphi) Disco 2 Td5 battery lasted 10 years and 190k miles.
My Puma Defender battery (also Delphi and I think identical to the Disco) is now at 7 years and 142k miles, and occasionally gives signs of old age - very occasionally it is reluctant to crank.
The Puma engine support systems definitely seem to draw significantly more power from the battery prior to cranking than the TD5.
Post #329216 8th May 2014 9:34am
grafty99
Recently I have replaced the battery on my Td5 90, 12 years and 103,000 miles. Not too shoddy Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #329252 8th May 2014 12:25pm
My battery is 6 years old and still going strong. Mr. Green
Post #329253 8th May 2014 12:31pm
landy andy
My battery is still doing its job, as it's starting the engine every time. But it's only since fitting the battery monitor that I noticed this drop in power. So with out monitor I would have said my batteries were good. They are probably six or so years old and have done their job well in all situations, so can't complain. Just not that happy in parting with £500.
Andy.
Post #329262 8th May 2014 1:09pm
gilarion
That's two of us! I do not know how i managed without my CTEK charger, it does what it says and has brought two of my old batteries back to life. I do not know what is in that little box but it performs magic.
Post #329264 8th May 2014 1:16pm
ericvv
Same here, 5.5 years old original battery. Even when the truck sits idle for a week or so, before starting it again, my battery tester will still show a charge of 12.5V Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #329277 8th May 2014 1:48pm
landy andy
Mine will still show 12.5 volts. But then I turn on the ignition and down it goes.
Post #329298 8th May 2014 2:51pm
landy andy
Pair of oddesey's ordered. Hope this gives me a change in voltage read out.
Got some good advice on looking after the new ones so hope they will last longer.
Andy
Post #329428 8th May 2014 8:41pm
