![]() | Home > Maintenance & Modifications > New gearbox? |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
I had a similar problem but not as bad however had a slipping clutch. Took mine off to find a seal gone so like you decided to go for a ashcroft box with the taller 5th and been spending the last few nights fitting it. I would say it sounds a good price knowing the work involved.
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
Thanks for the reply. Reading it back I probably should have said "overall price" rather than "rate" in my second question. I have done a couple of gearboxes myself, but always in older defenders, where I have opted to take them out through the cab. I decided this wasn't really as easy in my current td5 due to electrics and comparative comfort 'things' to remove, like carpets.
I don't really have the equipment to take it out from underneath...which undoubtably will be a lot easier but, like you, think the labour charge is reasonable. 2002 110 td5 |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3675 ![]() ![]() ![]() |
Have you tried jacking each axle up and turning the wheels backwards to try and see where the problem is, does it do it in gear or out of gear or both, is the diff lock on the transfer box working ok, does it do it high and low range, does it do it with 1 or the other prop shaft removed? DEFENDER 90 TDCI XS,
It does it in both high and low...worse in low. I have also removed each prop in turn and it still does it.
It is strange as when driving forwards it is not too bad, although there is an increasing amount of slop in the transmission when I back off the throttle. It only does it when in reverse gear. In neutral I can quite easily push the car backwards. As soon as I drop it into reverse gear it locks up and needs to be driven backwards to release it. Even with the clutch pressed and the car rolling backwards it binds. As it is rolling backwards, if I am lucky enough to be able to knock it out of gear, the binding stops. 2002 110 td5 |
