Home > Technical > Enlarging aperture where aerial cable goes behind dash
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Hi
Replaced standard aerial with CB aerial. However, want to leave this in place permanently so planning to thread the cable behind dash through same opening used by standard aerial cable.
However, CB aerial cable already has connector soldered onto the end. This is quite a fat connector and I don't want to cut it off as I don't have a crimp tool to fit another one. So was wondering if I could increase the size of the aperture and use a grommet like this or will I risk water getting in behind the dash?
Post #328485 5th May 2014 10:39am
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Bit risky i would say.
Is it a normal BNC connector? a new one can be bought from anywhere, even maplin and it is easily soldered on and will give a much better finish and sleep at night Wink William
Post #328495 5th May 2014 12:08pm
kmac
Its a PL-259 plug, soldered on really well. I would have to cut it off really and get a new plug
Just means I cannot do the job today
Post #328508 5th May 2014 12:46pm
Happyoldgit
Why make the job more difficult than it needs to be? I can't make out if the PL 259 is soldered or crimped but I'd de-solder / cut off the connector thread the co-ax where it needs to go then solder a new plug, if it means waiting for a few days then that's what I'd do. Steve.
http://forums.lr4x4.com
Post #328512 5th May 2014 12:55pm
kmac
Taken it under the bulkhead and into space under the drivers seat for now.
Will order another connector and do the job properly on another weekend
Thanks all for advice.
Patched in a little box of tricks that allows same antenna to be used for AM/FM radio as well as CB
Post #328523 5th May 2014 2:35pm
K9F
PL 259 connectors are available as a clamp on option that will give excellent connectivity without the need for soldering or crimping and can be used again and again.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #328537 5th May 2014 4:04pm
kmac
Thanks K9, was not worried about the solder, just didn't have a spare connector and my soldering iron ( 30W Antex) was not melting the solder on the existing one
I didn't know about the clamp on ones thought, since found out that Maplins sells them
Post #328621 5th May 2014 9:30pm
kmac
Sorted out the job properly today. Pulled the old aerial cable through with a wire tied to end of it.
Pulled new Cb aerial cable back into the car using the wire.
Not so sure about the compression connector though. Have soldered the central bit but the cable seems to be held in place by the braiding being clamped
Post #330075 10th May 2014 9:49pm
