Home > My Defender > Benmatt912 - First Defender
Page 2 of 2 <12
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Great to see a proper land rover on the forum! - Classic wheels look spot on!
Post #328046 3rd May 2014 3:48pm
Jambo
Your alloys look like disco one's which won't clear the landy hub, without a bit of machining or die grinding but they can be made to fit. its quite dangerous like they were as they don't sit on the hubs flat and can come loose Evil or Very Mad
James
Post #328138 3rd May 2014 9:19pm
Smilesapart
I prefer it with the steels tbh
Post #328142 3rd May 2014 9:27pm
"I prefer it with the steels tbh"
Me too - although wolf wheels would look best. Thumbs Up
Post #328235 4th May 2014 10:09am
Benmatt912
United Kingdom 2001 Defender 90 Td5 HT Coniston Green
Chocks, don't need them do I....
Had an eventful day, started by moving stuff for my brother to his new house. Decided to swap the rear drivers side tyre over as the garage had put the spare on after replacing the rear cross member.
I blame the following incident on laziness, I couldn't be bothered to get the chock out from the battery compartment and thought that as it was on flat ground it should be fine. Sadly it wasn't. I got the car jacked up and the tyre off when the car rolled forwards and fell off the jack.
Luckily the not as flimsy as it looks cover for the disc brake stopped the axel before the disc hit the ground. Sadly in the process I managed to slightly bend the jack and the mounting point in the brand new rear cross member. After a visit to halfords and the purchase of a 3 ton trolley jack and some 4 ton axel stands we got the landie lifted up and the tyre on.
After all that we went to the fireworks champions at eastnor castle and I made full use of the landies off-road grip and side angle to bypass most of the ques on the way out, following a very nice white 130.
All in all a fun day, and I now know that I should always use chocks when jacking the car up.
Post #452637 6th Sep 2015 12:38am
Venomator
Great looking Landy Ben and in a super shade of Green... Mr. Green
We all learn from our mistakes matey, some are more expensive than others... Rolling Eyes
Looks like you've tidied that back end up nicely and got your new back door fitted in the end?... Thumbs Up
Keep up the mod work and do let the progress images keep coming... Mr. Green
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #452657 6th Sep 2015 8:28am
"The only real mistake is the one from which we learn nothing."
Just glad for you it did not cause any physical harm or prove to be expensive.
Post #452727 6th Sep 2015 11:47am
need4speed
No real harm done. It can happen to the best of us.. Glad you got rid of the old rangerover style wheels. Looks so much the better for it Thumbs Up
Post #452730 6th Sep 2015 11:57am
Benmatt912
Bit a couple of bits this weekend. Fitted a pair of covers to the Windscreen brackets. They were looking pretty tatty and due to the supports for the roof rack bolting through them I really didn't fancy buying new ones and drilling a hole through them so managed to purchase a set of Black plastic covers for £15 of Ebay.
Before
After
Have been trying to decide what to do about a recovery point/ somewhere to attach a rope to pull things with for a while and now that the rear cross member has been replaced I decided that the tow ball/hitch off of the Dixon Bate that came with the landie would work quite well. I didn't fancy refitting the whole assembly as it weighs a hell of a lot and due to my license I cant tow trailers so don't need it to be lower, just a strong rope/strap attachment point.
Venomator - I have indeed managed to get the rear door replaced back in June 2014. It looks a lot better, still leaks around the handle and where the spare wheel carrier is fitted, but is a lot better than the old one. I really didn't like the old door card, so didn't get it fitted. The plan was to make one from some plywood, but that hasn't happened and i am in no hurry to do anything with it as I quite like the practical look of being able to see everything.
Post #454793 13th Sep 2015 9:22pm
"set of Black plastic covers for £15 of Ebay. "
Not seen them before, do you have a link you could post Thumbs Up
Post #454882 14th Sep 2015 9:42am
dorsetsmith
are your rims (tubeless type or do you need in tubs ) Question lettering stamp in to the rims, only i fond out when i had tyre changed Exclamation
Post #454890 14th Sep 2015 10:01am
Benmatt912
update
So its been about two and a half years since my last update.
Im still really enjoying the landie and while some people question why I have it,rather than a "Normal" car, I enjoy driving it and it is just so useful. I dont worry when there is talk of snow on the weather or when I am asked to move a set of ladders from A to B.
Towards the end of last year I ended up driving down to High Wycombe every couple of weekends, which is about a 200 mile round trip on the motorway. This sadly was the straw that broke the camels back, or to be more accurate finished off the bearing on fifth gear.
But now with a reconditioned gearbox, new clutch, dual mass flywheel and thrust bearing the landie is happy and a lot quieter. The need to drive to High Wycombe has also gone and the landie is back to only going on the motorway once or twice a year.
The plan going forward is:
Get and fit a new headlining, as I removed the old one over a year ago when I started insulating the roof.
Replace the seats, as the current ones are quite tired
Buy and fit LED lights all round, however I am still trying to decide between the clear lenses or coloured lenses
Post #692618 11th Mar 2018 5:08pm
familymad
Sounds like you are having lots of Landy adventures but ironing out all the issues Thumbs Up 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #692621 11th Mar 2018 5:13pm
L110CDL
Great your still enjoying the landy Very Happy Thumbs Up Clayton.
Keeper.
Post #692734 11th Mar 2018 11:39pm
Page 2 of 2 <12
