Home > In Car Electronics > 110xs sw add 2nd row interior light
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
I am trying to add a light to the second row. There is cabin light in the first row and 3rd row but strangely not the 2nd row. What is theasiest way to do this? Can I just tap the cable from the 3rd row light? Is the current sufficient to run 2 lights?
Post #327877 2nd May 2014 5:26pm
VeeTee
Netherlands
Yes you can Smile
Additionallly you could change the bulb for LED bulbs, I sourced them on Ebay...
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #327878 2nd May 2014 5:44pm
If you use LED lighting then you can tap in to the original as the power consumption is MUCH lower. Using incandescent bulbs though is a no go.
Look in my gallery under interior lighting and you will see some ideas there. Thumbs Up
Post #327880 2nd May 2014 5:45pm
ronwong
I bought the lamp housing/ switch. Its a on off and door mode. So I can just connect parallel by pulling 3 cables from the 3rd row?
The bulb is another thing, in fact I am happy enough with the original bulb
Post #327881 2nd May 2014 5:47pm
That's not true, Steve. Whilst LED's are very nice, the standard bulbs are still less than 1 amp each and adding a second is well within the capabilities of the wiring. People were doing this sort of mod long before LED's became common. Darren
Post #327887 2nd May 2014 6:18pm
ronwong
I pulled from the front. Just a cable about 1m for each, the 2nd row light does not dim in door mode with the first and 3rd row and also is much dimmer. Maybe it's bad wiring, I will try to do it again.
Post #327986 3rd May 2014 10:23am
LRA I didn't know that, if the wiring can take it then all very well. All the same it's not designed to take more.
Or less for that matter but in my case I matched LED consumption pretty closely.
Post #327989 3rd May 2014 11:02am
