Home > Maintenance & Modifications > Puma water temp gauge function
Page 2 of 3 <123>
ericvv
munch90 wrote:
The ECT gauge is driven by high speed CAN bus messages from the ECM. For normal operating temperatures the gauge
needle pointer is positioned centrally in the gauge display. The needle pointer position translates to the following
approximate temperatures.
Engine Coolant Temperature °C (°F) Needle Pointer Position
Ignition off Park position
40 (104) Cold (blue segment)
75 - 115 (167 - 239) Normal (central)
120 (248) Start of hot (red segment)
125 (257) End of hot
from manual
Munch, if that is indeed how it really functions, there we have the problem. It is not normal that a water temp gauge stays firmly in the middle until the water temp reaches 115°C....
Now, if the manual says that, it forgets to mention that indeed between cold and what must be 75°C, the needle moves nicely and gradually up and down with increasing or decreasing water temp....
So the question remains, why couldn't it do the same above 75°C and keep gradually moving up with the water temp from middle til the red line....
That would give the right and timely warning signal.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #327713 2nd May 2014 6:15am
Naks
One of the reasons why the needle stays in the middle on most vehicles is to not alarm people unnecessarily? Confused --
Post #327753 2nd May 2014 9:32am
Cheshire110
115? Normal?!
Speaking of which, 115 appears to be the temp that mine goes into limp mode so that all seems right above. Strange thiugh.
You'd think that there should be a 'high' zone from say 95-115 to warn you it's running hot then... Cheers, David
Post #327755 2nd May 2014 9:45am
ericvv
I don't think it does that on most vehicles. On most vehicles this gauge will move more or less linear with rising and lowering water temp to give you reality picture. As the Puma gauge perfectly does between cold and "normal" level by the way, so technically it must be possible for it to do that all the way to red too.
Frankly, the way the Puma water temp gauge is set up from "normal" to "dangerously high" level is straightforward Ostrich Policy..... No more, no less.
Post #327767 2nd May 2014 10:27am
Naks
Nope, not so.
In every single vehicle I have driven, the temp gauge moves slowly to the normal position and then stays there, even though we all know the coolant temp is constantly changing.
On my Sentra, Defender Td5, Disco Td5, old Audi A3, brand new Audi A3, my brother's Corsa, brand new Touareg, etc.
This is why I have the EMS - I can see what is happening to the coolant temp and can adjust my driving depending on the ambient temperature, slope of the road, towing/not, etc. --
Post #327768 2nd May 2014 10:35am
ericvv
^^ and stays there..........
OK, I guess you mean above normal in this case.
In any case my Puma gauge when it reaches normal, but when in colder weather conditions I get into stationary trafic, the gauge will continue to gradually move back down in direction of the cold level in line with eventually lowering water temperatures.
So between cold and normal, the gauge shows continuously the real water temp, but not above.
My viewpoint remains unchanged, as the Puma gauge is set up to fly up straight from normal to the red zone at a already dangerously high temp of 115°C or so, there is little time given to react and to avoid engine damage. So it would be worth something to me if this could be reprogrammed in order to get away from this ostrich policy and just show the real thing. Thumbs Up
Post #327780 2nd May 2014 10:53am
munch90
the gauge is too small and needle movement area too small to give a accurate reading anyway , to give a temp change of 1 or 2 degrees on the gauge you would have to have a magnifying glass to see needle has moved
any proper temp gauge will have a scale much longer like right round the face of the gauge ,
some cars now don't even have a gauge at all just a light
Post #327785 2nd May 2014 11:14am
K9F
Why don't we have a whip-round and buy Eric a suitable bluetooth gizmo or a Scangauge perhaps? I'm in!
If it ain't broke don't mess with it!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #327787 2nd May 2014 11:17am
Happyoldgit
Ah but it might be broke and just not showing it Laughing Does this mean Caterhamitis could be contagious? Shocked Steve.
http://forums.lr4x4.com
Post #327788 2nd May 2014 11:28am
ericvv
Thumbs Up
Luckily no need for that. I would rather have a functioning water coolant temp gauge, which would give a decent indication when water temp rises above normal, and I surely am not interested if the temp is exactly at 83°, at 84°, and so on, so a well functioning standard temp gauge could do just that. And as said, I would happily have paid for such a software change. But seems problematic I guess.
I surely am not interested in the scangauge gizmos, and if it appears that there is no cure for this with the standard water temp gauge, I already have in mind a different solution which will give the correct water temp and which will fit my dash like a glove. Whistle
Post #327792 2nd May 2014 11:56am
K9F
Crack on with it and then share the information for anyone that may be interested! Or share now to see if there are any flaws!
Post #327794 2nd May 2014 12:00pm
ericvv
I am thinking of putting this type of VDO gauge into the side of the center dash with the right sensor at the engine for the water temp. Now don't ask me about technicalities for this, I guess I will ask my dealer or another specialist to do it.
In any case this type of classic VDO gauges suits a Defender quite well I think.
Anybody have done this already, or any comments, suggestions, is there enough space behind the center dash side for this gauge, maybe someone kill the idea as unworkable.....? Comments and advise welcome Thumbs Up
Eric
http://www.ebay.co.uk/itm/VDO-Water-Temper...3f1f0f5caa You never actually own a Defender. You merely look after it for the next generation.
Post #327802 2nd May 2014 12:35pm
munch90
40-120 so much the same as standard one
Post #327806 2nd May 2014 12:45pm
ericvv
Correct, but it shows the real water temp, and I am not going to wait until it is showing 120°C before taking some action. Laughing
Think this type of VDO gauges which is a sober design which exists already for many decades fits the Defender design very well. Thumbs Up
Nobody on here has done that sofar?
Post #327826 2nd May 2014 1:24pm
ericvv
My main question to you technical wizzards now is, while leaving the sensor/sender of the standard Puma water temp gauge in place, so keep letting the standard gauge do its standard thing Cool , is there another obvious place on the Puma engine where I could put another VDO water temp sensor/sender for the VDO gauge?
Post #327829 2nd May 2014 1:42pm
Page 2 of 3 <123>
