![]() | Home > Puma (Tdci) > Narrowing down the problem-Overheating |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5990 ![]() ![]() |
"but i wouldn't change anything."
Apart from the viscous fan, the................ Andy |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2789 ![]() ![]() |
hi there, a point i'd not thought of...
can you point me in the direction of some instructions on how to flush the system? Does it involve draining all the coolant & replacing with new i guess? Im sure theres a sticker in the engine bay which says " Do not drain coolant! " haha... Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
the manual says to vacuum fill ,
if your going to flush system ,when you refill pour coolant in slowly it helps reduce air locks |
Been keeping any eye on mine since this post, and the temp never goes above 84-85c. So yours does apear permenantly hot
Andy |
Whitewaitress Member Since: 26 Nov 2013 Location: Liverpool Posts: 47 ![]() |
http://www.defender2.net/forum/post324325.html
2nd post in the above link kindly supplied by dgardel - the relevant file is in the link but for the 2.2 tdci. Mine is the 2.4 but so far the jobs I've done have been broken down step by step and have been illustrated perfectly from the 2.2 manual dgardel has provided. There's a little yellow sticker half hanging on mine which says use genuine LR coolant, probably a safe bet ![]() As munch90 rightly pointed out, it does say to vacuum fill but I didn't have the tools for this & gave it a go anyway. Releasing the breather screw does help with air locks, good point on pouring slowly too - made the mistake of pouring too quick in the past ![]() If you are going to change, try a good coolant flush product to lift & remove any solids flowing around the system. I found the small hose from the bottom of the radiator to the fuel cooler was preventing fluid to flow when I flushed mine. Keep us posted on your findings, |
Ok thanks all...
First job will be fitting the replacement viscous coupling & fan I've got.. Hopefully that's it, After that the troubleshooting gets more and more vague... Hmmm Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
It definitely is getting hot, can hear the coolant boiling...[/quote]
can you hear water boiling or air bubbling up the hoses |
99% sure boiling, readout on OBD gauge, hot smell and limp mode all agree too.. Cheers, David
Slightly off topic, but is it the same spanners to remove a Tdci fan as a Td5?
Andy |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Landy andy do you mean viscous fan ? If so the answer is no the Tdi is 32mm and a left hand thread and the Td5 is 36mm and right hand thread.
Hope this helps. 2005 Td5 90 XS Steve |
Yes that is what I ment. So
![]() ![]() Andy |
I don't know what the answer is, but it's worth noting that whilst you asked about the Tdci, Lou's reply was about the Tdi. It could just be a typo but could also be a completely different engine. Darren
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
Had something similar on my 2010my 90. Scanguage started showing variable temperature readings over 72 hrs, going upto 98c but instrument pod temperature didn't move. Then on a longer journey climbing out from Symonds Yat up a longish steep hill temp went upto 105 then down to 98 . Heater on at the time and working. Then joined A road, temp climbed to 108 on Scanguage, instrument temp shot up, limp mode and pulled into layby. AA called, no coolant loss, fan seemed to be working ok, but found radiator was stone cold, although pipes were warm. Recovered home. Local Indy, that knows car, diagnosed thermostat failed closed. Replaced and all is well. Apparently not an easy job to do. LANDYWATCH
![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Just re read this and it was my error I read Tdci as Tdi
![]() Steve |
