|  | Home > Technical > Td5 crankshaft pulley |
| CDS Member Since: 28 Jun 2010 Location: Oldham Posts: 15  | http://www.defender2.net/forum/topic19647....aft+pulley
 Any help to you pal? | ||
|  28th Apr 2014 11:25am |
| Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812    | I would change asap...
 I also have a tool to lock the pulley if you want to borrow it. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 | ||
|  28th Apr 2014 11:40am |
| amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452      | Ok Ian ,
 Appreciate your advice   Thanks for the offer of the special tool that's very good of you, I might take you up on that   Will be in touch, Don't suppose you have a pulley/ damper going cheap do you mate? I believe genuine is the way to go?  | ||
|  28th Apr 2014 11:47am |
| Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812    | Genuine is definitely the way forward - well OEM spec as you can not buy them from Land Rover any more - have been removed from service.
 I 'might' have a used one - will check. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 | ||
|  28th Apr 2014 1:46pm |
| amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452      | Thanks Ian I really do appreciate your help   | ||
|  28th Apr 2014 2:34pm |
| amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452      | Ok a bit of an update,
 Had a closer look tonight at the rattle. Removed fan and examined the crank pulley. Initially looking for play by holding in both hands and trying to move it up and down and side to side. I could not find any play. Put socket on big nut at centre of pulley and moved it back and forth quickly and all was solid with no play or knocking   I ran the engine and viewed the pulley from above and expected to see a blur as the pulley vibrated from side to side, but it looked fine. BUT still could hear rattling noise. I then removed the belt and ran the engine, no rattling noise   So I think the pulley itself is ok, and now need to locate the offending item. I will have another look at the weekend but has anybody had any experience of a rattling noise being made by any of the pulleys or items that the belt turns? My first thought was the belt tensioner? I spun it by hand and it did not make any awful noises, I did the same with the the other pulleys but could not detect the source of the rattle   Any advice very much appreciated  | ||
|  28th Apr 2014 7:31pm |
| Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006    | Grab hold of the ribbed bit that the polyvee belt runs on on the crank pulley and see if that rotates separate to the crank pulley itself it that makes any sense. From the description you're giving I'm 99% certain your crank pulley is toast sorry | ||
|  28th Apr 2014 7:48pm |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059    | This any help
 http://www.discovery2.co.uk/CrankPulley.html Andy | ||
|  28th Apr 2014 7:54pm |
| amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452      | Cheers Andy
 Had seen that earlier but now having read it a bit more carefully I agree I think it probably is toast. I'll have a closer look asap  | ||
|  28th Apr 2014 8:30pm |
| amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452      | Another update,
 Dug a little deeper tonight, removed damper and it was clear to see that it has had it   I made a tool out of some scrap steel and bolted it to the pulley to stop it moving. Then set about trying to remove the bolt and my god despite using the biggest bar in the world ( about 5 foot) I could not shift it. Got to stage where I worried about damaging something or myself   So I admit defeat, I will get local Indi to to it and let them have the pleasure. The other issue is that even if I did get it off my torque wrench only goes up to 300nm to I could not accurately torque it up. Thanks to all who had offered advice  | ||
|  29th Apr 2014 7:26pm |
| Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006    | Glad you sorted it    | ||
|  29th Apr 2014 7:30pm |
| Posting Rules
