![]() | Home > Maintenance & Modifications > Entreq security bonnet hinges |
ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817 ![]() ![]() ![]() |
A question for those who have installed these Entreq security hinges.
I have read that in the factory the Defender bonnet gets painted with the original hinges already installed, so when installing the Entreq hinges in lieu of the original hinges, does this leave a piece of unpainted or base painted metal of the bonnet visible? Or is the footprint of the Entreq hinges as big as or bigger than the original hinges footprint? I would like to know if I am facing a little paint job too when these Entreq hinges will be installed. Tks, Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Scan the base the and annotate with some dimensions and I can probably cut you a gasket from something like foam or rubber at work if you want.
Would have to charge for the job though as I have used my freebees for a while but would imagine only 25ish quid |
