Home > Puma (Tdci) > Narrowing down the problem-Overheating
Page 3 of 6 <123456>
Cheshire110
yep good point, i used our 'power washer' - kinda somewhere between the two i guess, no danger of damage. It looked pretty clean anyway...
yep going to get down to chris when i can anyway, will ask him to de map so i can have a quick test drive and then see if any different. Cheers, David
Post #326862 28th Apr 2014 11:10pm
It could well be a knackered viscous fan. Your description of no problems on a motorway and then overheating when you slow down reminded me of a similar problem that I had with a Stage 1 V8 years ago that was fine when moving fast but would overheat when crawling along. In my case it turned out that somebody had fitted the fan backwards so it was drawing warm air from the engine over the rad. The relevant bit though, is that moving at speed overcame the problem by just pushing air through the grill. In your case, if the fan isn't locking up properly then heat soak after slowing down from a higher speed or when under load could produce a similar result.
They easiest way to test it is first try to turn the fan by hand when the engine is cold (and off, obviously). This will give you a feel for the unlocked resistance. Then get the engine good and hot and try again. It should then be really stiff to turn compared to when cold. To be honest though, you should be able to hear the thing working as it sounds like a vacuum cleaner when it's locked up. Darren
Post #326863 28th Apr 2014 11:10pm
Cheshire110
the fan is definitely working, at least at tick over.
Think ill start with the map and then the thermostat, then ill start worrying if its neither of them...! Cheers, David
Post #326868 28th Apr 2014 11:19pm
Viscous fans will turn all of the time. They are not like electric fans that turn on and off. They operate by the fluid in the hub thickening as they get hotter, transferring more torque to the fan blades, much like a torque converter in an automatic gearbox. Hence, it will feel much stiffer to turn by hand when hot than when cold. Darren
Post #326872 28th Apr 2014 11:26pm
Cheshire110
ok so it could be turning at tick over (it didn't look very fast!) but then not increasing speed as required? That could be possible...
Why isn't it just belt driven haha? they never make it easy! Cheers, David
Post #326873 28th Apr 2014 11:28pm
Viscous is easy compared to electric Thumbs Up Darren
Post #326878 28th Apr 2014 11:33pm
Cheshire110
purchased a new viscous fan & coupling anyway. It was such a good price that i'd probably get my money back anyway if it doesn't fix the problem...
heres to hoping!
learn something new everyday.. cheers LRA Cheers, David
Post #326879 28th Apr 2014 11:33pm
Cheshire110
yes just realised that thinking it through.
my brain made the "I've not heard of that, therefore confusing expensive magical engineering complexity" connection... Cheers, David
Post #326881 28th Apr 2014 11:34pm
munch90
sometimes when you first start from stone cold the fan is noisier that's the sound you want when its blowing harder , they free up after running a few seconds then as it gets hotter they lock up or drag harder
just out of interest
fitting a fan backwards wont make it blow the other way ,but will make it less efficient because of the shape of the blades , if its rotation is changed it will blow the other way , but which way it has to turn to be most efficient is down to the shape or scoop of the blade
if its a electric fan wiring it up the wrong way or fitting wrong
Post #326902 29th Apr 2014 7:05am
Cheshire110
Very useful, thanks Thumbs Up Cheers, David
Post #326914 29th Apr 2014 9:01am
Munch, I know what you mean, but we discovered the problem purely by chance whilst standing in front of the grill and feeling warm air being pushed out. I guess it must have been some quirk of the curvature of the fan blades, but turning it around solved the problem, which I was very greatful for at the time! Darren
Post #326925 29th Apr 2014 9:42am
munch90
sorry but no, fan fitted backwards still blows same way just not as well
Post #327023 29th Apr 2014 7:20pm
Ah well, I must have imagined it then Laughing Darren
Post #327026 29th Apr 2014 7:36pm
Eduardo
As DW will do and to try to solve the problem (same as davidwhittaker) I decide to change the Viscous fan and the thermostat (already ordered from one of our site supporters).
I hope that will solve the problem because is drive me crazy.
We will see Neutral . Eduardo
Post #327082 29th Apr 2014 9:41pm
Cheshire110
hope we'll get it sorted soon, Defender ownership really is a full time job but i wouldn't change anything... Cheers, David
Post #327085 29th Apr 2014 9:46pm
