![]() | Home > Maintenance & Modifications > Garage says LightForce 170s need better wiring than OE... |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20998 ![]() ![]() |
100w afaik, mine are 100w spots too. Road legal, so long as it's switched correctly and front mounted not on the roof.
I think that is the way it is, open to advice though. You can either have it switched via stalk or switched via stalk and a switch too for independent use age from dipped beam headlights and main beam. 100w bulbs put into headlights aren't legal though. |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
This is an urban myth about maximum wattage of bulbs in headlights.
Under vehicle lighting regulations 8. Wattage– (a) A motor vehicle, other than a solo motor bicycle or motor bicycle combination, first used on or after 1st April 1986: No requirement (b) A motor vehicle, other than a solo motor bicycle or a motor bicycle combination, first used before 1st April 1986: 30 watts minimum They can be mounted on the roof as there is no legal requirement on vertical position. This can be checked here Brendan |
why don't someone make a higher wattage bulb for headlights that's e marked , brighter is ok as long as they set up right ,
hids are brighter so why can't we have a brighter bulb ? |
i think there is some reg that they can only work on high beam ( spotlights ) |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
Thx Brendan.
Considering a Lazer bar (as British made) for roof mounting & 2x 140s LF for rear (independently switched). Are Mantec roof bars the best choice for mounting lights on? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
Whilst there's no maximum wattage for main beam lights, the legal problem comes with e-marking. There are very few properly e-marked (as opposed to just having a printed sticker from China) bulbs available above 65w. Darren
Mantec roof bars are pre drilled for lights, may need to enlarge though.
Whilst there is no legal maximum on the wattage of a headlight bulb it would not be exactly wise to put a much higher wattage bulb in a standard headlight.
Reason being that wiring/switch/relay/bulb holder etc would have been designed to work on the bulb wattage supplied with the vehicle. Brendan |
According to their website, the Lightforce 170 in the OP is designed for 100w bulbs, so the wiring and switching would be designed to suit
![]() http://www.lightforce.com/products/170-striker/170striker Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
If you read the spec sheet the 170's come with a 100 watt Xenophot bulb as standard.
The UK distributors just lists the 100 watt bulb with the 170 lamps. However they do list a range of replacement bulbs from 20 to 100 watts Yes it is confusing the way that they mention E mark information. Brendan |
"If you read the spec sheet the 170's come with a 100 watt Xenophot bulb as standard."
Identical to Roolites too. ![]() Imo anything less than 100w as spots is pretty pointless. |
I must admit I'd assumed that the different spec was for the European market
![]() Steve, I'm surprised you're so casual about 100w bulbs given the concern you've shown about e-marking on other ones! Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
