![]() | Home > Technical > Which ABS system does a 2011 90 have |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
2008 XS 90 Wabco....It's labelled on the unit itself. If you go through life with your head in the sand....all people will see is an ar5e!!
| bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233
BA chassis number has a Bosch with a puma 2.4 CAN protocol
CA chassis number has the same Bosch unit but with some slightly different puma 2.2 CAN protocol. The BA puma with the Bosch unit was only produced for its last year of production as a 2.4 puma before it moved over to the 2.2. Pete |
| martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422
Thanks,
It looked like a bosch unit but I could`ent see it written on it, our wabco tester gave lots of ecu data but would`ent tell me what it really is. Mine is on a BA chassis number registered in july 2011 Do you know if its bosch 8 abs as I would like use the wiring diagrams I have for future reference, as at some point something is going to go wrong after all. If it is I will happily place them on here for others to use as they see fit... martin Ah yes your right had good look today if you have a good look down the right hand side of the unit you can see the word bosch printed on the unit you might need a good torch if its mucky . thanks again Excuse the spelling I`am better with spanners and wires. |
